Reveal Paragraph Panel shortcut not working properly
Mar 24, 2013 8:15 AM
Tags: #illustrator #help #mac #type #cs6 #paragraph_panel
It's Option+Command+T.
This happens after start-up...
  1. Formating text...create text on page
  2. Press select all (Com+A)
  3. Press 'Com+T" activate a field in the Character Panel,
  4. Press Opt+Com+-T to apply Paragraph level attributes... the Paragraph Panel does not appear.
  5. Switch to any other application that has some function for Opt+Com+-T (including The Finder) and it's working within the respective application.
  6. Return to Illustrator... and the Opt+Com+T function works.
  7. What is causing it to activate?
iMac 3.4GHz
32 GB Ram
Apple Wired Keyboard and Mouse
Intuos 4 Wacom Tablet
    Mar 24, 2013 11:37 AM   in reply to freehandvet
    Sounds like a conflict with some other software or the OS.
    Which version of Illustrator are you using?
    By the way, the default shortcut to highlight the font selection field in the Character palette is Cmd-Option-Shift-F
    Mar 24, 2013 3:03 PM   in reply to freehandvet
    Illustrator CS6 might be the reason, but I don't know for sure as I've trashed that version. In AI CS5 the shortcuts you're mentioning do work here.
    Passionate users of AI CS6 may have a look at your issue.
    Mar 24, 2013 3:45 PM   in reply to Kurt Gold
    works in CS6 on Mac OS 10.6.8 and 10.8.3
    The issue must be something else.
