CenekStrichel
Adobe Premiere Scripting Guide
Mar 25, 2013 7:30 AM
Tags: #import #scripting
Hello, I have to write some scripts for Premiere. It will import, cut and set rendering. I can do it in after effects, because there is Adobe After Effects Scripting Guide for CS6.pdf , but I cant find anything similar for Premiere But scripting in premiere is possible. I can find some commands in Data Browser in ExtendScript Toolkit editor, but I dont know how can I use it. (Import, edit etc.) Is for Premiere any scripting manual ? If not, why? Scripting in Premiere is not official supported? Thanks.
    Mar 25, 2013 7:32 AM   in reply to CenekStrichel
    You sure?  I thought it wasn't.
    Mar 25, 2013 7:53 AM   in reply to CenekStrichel
    This user to user forum is for how to use the program, not programming
    Try http://forums.adobe.com/community/premiere/premierepro_current/sdk
    May 16, 2013 12:05 PM   in reply to CenekStrichel
    Hi CenekStrichel,
    Since there is no scripting subforum, the Premiere Pro SDK subforum is a better place to ask about scripting at this time.  I'll move your thread over.
    Jun 2, 2013 11:32 PM   in reply to CenekStrichel
    Hello CenekStrichel,
    how can you send commands to premiere with the JSX-scripts? I also need this way to code some plugins.
    I just can't find a way to send the jsx code to premiere, 'cause there is no menuitem like in after effects/File-->Scripts.
    Please help!
    Best Regards
    Manuel
    Jun 3, 2013 4:58 AM   in reply to CenekStrichel
    Woooow you saved my life I thought I had to code all the stuff i need in C/C++.
    Yeah I know, I found a useful jsx-file called rd_GimmePropPath.jsx - this little script (including a GUI) can read all the propertys you need to call the text elements and stuff in after effects - maybe it can help to find something for premiere too.
    In after effects it worked quite well I'm trying it now for premiere.
    I also need to compose a full sequenz from jsx - including intro, effects, blending, outro and an after effects mov-file in between.
    I let you know if I can find something useful in after effects I made it step by step maybe it will also work here.
    thanks for your answer!
    Jun 3, 2013 6:26 AM   in reply to CenekStrichel
    Yeah only for After Effects tried it for myself.
    Do you know how to call the items of the project?
    Jun 3, 2013 7:03 AM   in reply to CenekStrichel
    for(var key in app.project){
                alert(key);
    try this to get the propertys of the project, if you found something useful edit the collection where you are reading the propertys - found the child members of the items (app.project.rootItem.children)!
    Jun 4, 2013 10:13 PM   in reply to CenekStrichel
    yeah it took me half a day to find out that all the stuff is in the data browser
    so that's what i found out yesterday:
    you can add an array of files like this:
    var myFiles = ["C:\\'theFilePath'\\File.mov", "C:\\'theFilePath'\\File2.mov", ...];
    app.project.importFiles(myFiles);
    and all files will be added to the project browser.
    also you can add a sequence to the project like this:
    app.project.createNewSequence("nameOfTheSequence","xxx");
    I don't know which param I had to choose for the "xxx", but it works if you set it empty.
    I'm currently looking for adding the files to the sequence, but I have to try some stuff till i find it out.
    Let me know if you find out something new
Bookmarked By (1)
