Maike_
Codec Problems/ avi. files
Mar 25, 2013 9:49 AM
Tags: #codecs #.avi #unsupported_format
Hello everyone,
I have been trying to fix this problem for a while now, but with no suitable solution.
Here is the thing:
I've been using Premiere CS 6 (Version 6.0.3) on my Windows 7, 64bit PC, quite a while now and it normally works like a charm,
but when I try to import certain .avi files, which I recorded with a camcorder, it keeps telling me, that the format is not supported.
I already tried it with severeal clips, but no luck there.
The thing is, if I try it on a friends Macbook it works fine and imports without and error message (she also uses Premiere CS 6).
So, I figured there must be something wrong with the codecs.
I tried to install different things to make it work, for example the whole divx codecs and the avid codecs,but nothing seems to work.
I ran one of the videos through GSpot, which tells me, that all the needed codecs are installed, but I really can't get the videos to work in Premiere.
https://pbs.twimg.com/media/BGNyTIcCUAEpNuk.jpg:large
Is there anyone who might help me with this issue or has the same problem?
I would be very, very thankful if anybody could help me solve this.
    Mar 25, 2013 10:43 AM   in reply to Maike_
    H.264 will not work inside an AVI wrapper http://forums.adobe.com/thread/854115
    -Insignia camera uses H.264 to either AVI or MOV... so use the MOV wrapper
    -Says VLC will convert in #6 http://forums.adobe.com/thread/1172956
    Mar 25, 2013 12:43 PM   in reply to Maike_
    Pr simply does not like H.264 inside of an AVI wrapper.  Try converting it to Lagarith or UT AVI files using VirtualDub.  The codecs and VirtualDub are open-source and free, and can produce very high-quality files.  Lagarith and UT are mathematically lossless codecs -- when they're decoded in Pr you get perfect pixel-for-pixel video compared to the source.  The only drawback is that they take up a lot more hard disk space than your source AVI files.
    Jeff
  • joe bloe premiere
    Dec 6, 2009
    Mar 25, 2013 12:51 PM   in reply to Jeff Bellune
    Mar 25, 2013 1:01 PM   in reply to joe bloe premiere
    Thanks, jbp!
    Jeff
    Mar 25, 2013 3:45 PM   in reply to Maike_
    You sure about that?  I'm not aware of any cameras that record H.264 to an AVI file.  It's about 90% MP4 and maybe 10% QuickTime.
    That suggests you're not playing with camera original media here, but something that's been converted.  If so, you may want to get your hands on the originals.
    Mar 25, 2013 8:33 PM   in reply to Jim Simon
    Number 7 in http://forums.adobe.com/thread/854115 mentions one
    I don't have that camera, so can't comment from personal experience... only reading what someone else said
    Mar 26, 2013 3:41 PM   in reply to Maike_
    I can't understand why a professional tool like Premiere can't handle H.264 in an .avi wrapper.
    Because it's just not an industry standard.  You will likely have to convert.
