Windbutnu
How to make symbol become designated drop area?
Mar 25, 2013 6:24 PM
Tags: #drop #cs5 #flash #as3.0 #symbol #area #become #designated
Previvious discussion http://forums.adobe.com/message/5173983#5173983
ok this is what I got so far, four squares on the grid, respectively named: squareC1, squareC2, squareC3, squareC4. Now I want the square that we named smallSquareName to be able to fit in any of the other four, how do I tell AS3 that smallSquareName can fit in any of these squareC1, squareC2, squareC3, squareC4, at the user’s will, because as it is now smallSquareName can roam freely all over the screen (not that it is a bad thing) But just like a game of chess I want smallSquareName to move according to the guidelines of the game.
Anticipating thanks
    Mar 25, 2013 7:50 PM   in reply to Windbutnu
    Dropping is a manual interaction involving releasing the mouse button.  If you are dragging the small square, you caqn control/limit where it can go by soecifying a rectanular boundary, but it is not clear how you intend to limit the movement.
    If you want to see how to implement the rectanglular boundary either look up the startDrag method in the help documentation ot search Google for "AS3 startDrag tutorial"
    Mar 26, 2013 4:23 AM   in reply to Windbutnu
    put your 4 targetsquares in an Array
    then upon releasing the mouse (stopDrag),
    check if the "PAWN" collides with any of these 4 squares
    with hitTestObject, and if so
    Tween it to the position of this square
    if not
    Tween it back to the place where the player started his dragging
    Mar 26, 2013 4:35 AM   in reply to Windbutnu
    You need to make your game intelligent enough to know what targets are valid ones for any movement of the small square. As the oher response indicates, you could place all the legitimate targets into an array an check if that array contains the drop target when the drop occurs, and if so, align the small square to that drop target.
    Mar 26, 2013 11:40 PM   in reply to Windbutnu
    No offense, but at this time you have shown no line of actual code you have written, nor a screenshot of a mockup you made.
    This is a repeating patterrn, obviously, because the last thread you made (and linked to in the first post) didn`t show anything you have written, too.
    I doubt anyone will fix your files for you.
    when I try to use the  hitTestObject mentioned Im getting all sort of error
    Show the errors, and show the code that is triggering them
