rickylcw1990
I need to create a formular on the web page .
Mar 25, 2013 9:51 PM
I need to create a formular on my web page like;
                <td align="center">$<?php echo $row_Recordset2['a100']; ?>*<?php echo $row_Recordset1['margin_100']; ?></td>
But the '*' is display to the web page like a text but not a function.
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Mar 25, 2013 10:14 PM   in reply to rickylcw1990
    You mean you want to hyperlink the '*'?
    Mar 25, 2013 10:43 PM   in reply to rickylcw1990
    I think it best if you give us a link to your site. The markup that you have shown should only produce a '*'. The problem may be caused elsewhere.
    Mar 25, 2013 11:19 PM   in reply to rickylcw1990
    Try
    <td align="center">$<?php echo ($row_Recordset2['a100'] * $row_Recordset1['margin_100']); ?></td>
    Oct 15, 2010
    Your code will not 'multiply' the 2 values. It will display the 1st, a * and then the 2nd value.
    To be able to multiply both values, you have to create a variable and define the multiplication outside of your table. Then echo that value within your table.
    See this tutorial to know how to multiply values in PHP: http://www.homeandlearn.co.uk/php/php2p8.html
    Oct 15, 2010
    Mar 25, 2013 11:20 PM   in reply to Sudarshan Thiagarajan
    Ben, we posted at the same time!
    @ricky: Ben's suggestion will work.
    Mar 25, 2013 11:28 PM   in reply to rickylcw1990
    HTML does not support mathmatical functions or any other types of calculations. Currently you are outputting values from your php script, but performing your calculation outside your script. You need to perform calculations WITHIN your script. Try
    <td align="center">$<?php echo $row_Recordset2['a100'] * $row_Recordset1['margin_100']; ?></td>
    EDIT: ah, a few minutes too late
    May 8, 2013 7:03 PM   in reply to rickylcw1990
    number_format((float)$number, 2, '.', '')
    May 8, 2013 8:32 PM   in reply to rickylcw1990
    <?php echo number_format((float)($row_Recordset2['a100'] * $row_Recordset1['margin_100']), 2, '.', ''); ?>
