JamieM216
issue when installing JQuery mobile App
Mar 25, 2013 11:00 PM
Tags: #jquery #dreamweaver #html5
Hi, i realy hope someone can help. I have developed an Android App in dreamweaver SC5.5 using  jquery mobile. The app itself works fine but when installing it tells me the app has permission to access all of the androids features, eg: test messages, camera, memory etc. How can i change this?
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Mar 25, 2013 11:22 PM   in reply to JamieM216
    Your app demands those 3 features from your device. So, your device is letting you know that your app will have access to those. If that's how you want it, you can safely confirm the message and proceed with installation.
    There's no way that you can disable the device from prompting for permission when your app is programmed to use those features.
    Mar 25, 2013 11:47 PM   in reply to JamieM216
    Sudarshan can correct me if I am wrong, but what I infer is that you can choose to access Android features from your application if you want to. Whether you want to access them through your application is your discretion. It does not imply that  your application will be using/forced to use those features.
    Oct 15, 2010
    Mar 26, 2013 12:25 AM   in reply to Preran
    +1 Preran. That is why your device is prompting to let you know that your app 'demands' the use of those features. Its at your users discretion to allow/ disallow that.
    @Jamie: Glad you've found a fix. Good luck!
    Mar 26, 2013 12:57 AM   in reply to JamieM216
    Hi Jamie,
    If this is an XML file from within Dreamweaver, can you post the name of the file here so that other users could benefit from it?
    Preran
