flexprabu
How to get SWF???
Mar 26, 2013 2:46 AM
    I need generate swf in flex application like i have save function using file refference.If i click the save button the particular component generate as SWF is this passible in flex????????????????
    Mar 26, 2013 6:33 AM   in reply to flexprabu
    You need to Export a Release Build from the Project menu
    Then got to the bin-release folder of your application and get the files from there.
    Mar 27, 2013 4:22 AM   in reply to flexprabu
    I don't believe you can generate a SWF from a running SWF.
    Mar 27, 2013 4:30 AM   in reply to flexprabu
    Well, there is this AS3 to SWF code.  I have not tried it and it looks like it isn't complete.
    Mar 27, 2013 4:54 AM   in reply to flexprabu
    An AIR application runs on the desktop and has more capabilities (less restrictions) than a Flash/Flex application that runs through a browser.
    Mar 27, 2013 6:33 AM   in reply to flexprabu
    flexprabu wrote:
    Ok thanks bcoz i have seen one air application in flex. that application has this type of option thats why am asking .
    If you see the option, then just use the example you found.
    The AS3 to SWF code is the only thing I found.
    Mar 27, 2013 10:10 AM   in reply to flexprabu
    I suppose you could upload source files to a server and have it generate the SWF and then download  it.
    A Flash app (not AIR) only has download options to put files on the client.  There is no other file i/o.
    I suppose you could also make minor adjustments to the byte array of a SWF if your changes are minor, but I don’t know anybody who has done that.
