heartgoon
swf generated by ant works not well
Mar 26, 2013 5:00 AM
Tags: #swf_flex_mobile
i have a flex mobile aplication in flash builder4.6,which generates a swf .
using the swf,i got a apk by adt which run well.
to make apks automatically,i use ant to compile the project.
the build.xml was generated by the sourcemate plugin and i had very little modifications to it.
then i got a new swf without error,with which i generated a new apk.
its a pity that the apk didnot run well.
can some body help,iam stuck!
build.xml:
<!-- This build file provdes a close approximation of the build process
     and build settings inside Flash Builder, but it is not an exact copy.
     Please customize this file as necessary. -->
<!-- Generated from project settings as of 13-3-26 下午7:23 -->
<project name="MyFlexTest" default="build" basedir="E:/Myfile/workspace/MyFlexTest">
    <property name="FLEX_HOME" value="C:/Program Files (x86)/Adobe/Adobe Flash Builder 4.6/sdks/4.6.0"/>
    <property name="SDK_VERSION" value="4.6.0.23201"/>
    <taskdef name="mxmlc" classname="flex.ant.MxmlcTask" classpath="${FLEX_HOME}/ant/lib/flexTasks.jar"/>
    <taskdef name="compc" classname="flex.ant.CompcTask" classpath="${FLEX_HOME}/ant/lib/flexTasks.jar"/>
    <taskdef name="html-wrapper" classname="flex.ant.HtmlWrapperTask" classpath="${FLEX_HOME}/ant/lib/flexTasks.jar"/>
    <taskdef name="asdoc" classname="flex.ant.AsDocTask" classpath="${FLEX_HOME}/ant/lib/flexTasks.jar"/>
    <property name="PROJECT_DIR" value="E:/Myfile/workspace/MyFlexTest"/>
    <property name="SOURCE_DIR" value="${PROJECT_DIR}/src"/>
    <property name="OUTPUT_DIR" value="E:/temp"/>
    <property name="LOCALE" value="en_US"/>
    <target name="build">
        <antcall target="compile"/>
    </target>
    <target name="clean">
        <delete includeemptydirs="true">
            <fileset dir="${OUTPUT_DIR}" includes="**/*"/>
        </delete>
    </target>
    <target name="compile">
        <mxmlc
            file="${SOURCE_DIR}/MyFlexTest.mxml"
            output="${OUTPUT_DIR}/MyFlexTest.swf"
            locale="${LOCALE}"
            static-rsls="true"
            accessible="true"
            actionscript-file-encoding="UTF-8"
            keep-generated-actionscript="true"
            incremental="true"
            <load-config filename="${FLEX_HOME}/frameworks/air-config.xml"/>
            <source-path path-element="${SOURCE_DIR}"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/authoringsupport.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/charts.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/flash-integration.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/framework.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/osmf.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/rpc.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/spark.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/textLayout.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/mobile/mobilecomponents.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/libs/air/servicemonitor.swc" append="true"/>
            <library-path file="${FLEX_HOME}/frameworks/locale/${LOCALE}" append="true"/>
            <library-path file="${PROJECT_DIR}/libs" append="true"/>
            <external-library-path file="${FLEX_HOME}/frameworks/libs/air/airglobal.swc" append="true"/>
            <library-path dir="${FLEX_HOME}/frameworks/locale/${LOCALE}" includes="*" append="true"/>
            <library-path dir="${PROJECT_DIR}/libs" includes="*" append="true"/>
        </mxmlc>
    </target>
    <target name="asdoc">
        <asdoc output="${OUTPUT_DIR}/asdoc" lenient="true" failonerror="false">
            <doc-sources path-element="${SOURCE_DIR}"/>
        </asdoc>
    </target>
</project>
