Using 'Copy Motion as XML' with a Motion Tween
Mar 27, 2013 5:54 AM
Tags: #motion #motion_tween #motion_tweens #copy_motion_as_xml
My problem is as follows:
  • I create a movieclip on stage
  • I create a Motion Tween for the movie clip
  • I select the layer and all the frames on timeline
  • I use Commands -> Copy Motion as XML
However, the XML copied only contains the first <Keyframe> declaration. If I convert the Motion Tween to a Frame by Frame animation and then use Copy Motion, it works. But reading this page: http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/mot ionXSD.html I understand this should be possible with Motion Tweens too.
Any ideas what I'm doing wrong, or is this a bug?
Thank you in advance!
    Mar 27, 2013 7:03 AM   in reply to Jani Palovuori
    Here is a tutorial from Adobe, back when it was introduced.
  • kglad
    Jul 21, 2002
    Mar 27, 2013 7:15 AM   in reply to moccamaximum
    (that's copy motion as as3 which is what the op should use if they want to use a motion tween.)
    copy motion as xml is best used for classic tweens.
  • kglad
    Jul 21, 2002
    Mar 27, 2013 8:48 AM   in reply to Jani Palovuori
    use a classic tween and copy as xml.
  • kglad
    Jul 21, 2002
    Apr 1, 2013 6:00 AM   in reply to Jani Palovuori
    if you want to use a motion tween, use export as actionscript.
