Mustang813
Removing Lens Flare Effect
Mar 27, 2013 10:16 AM
How do I remove the lens flare effect that I applied to text in my design?
    Mar 27, 2013 10:47 AM   in reply to Mustang813
    depends if you still have the psd
    can you post up the graphic?
    If you do not have the psd saurce file, then you in for a lot of work depending on how bad the background is
  • Noel Carboni
    Dec 23, 2006
    Mar 27, 2013 12:13 PM   in reply to Mustang813
    Is it all pixels, or do you have things in layers?  I think that was the basis of Frank's question.  If, for example, you have the lens flare in a layer, mixed with those below with e.g., Screen blending, then you'd just be able to shut off that layer by clicking the eyeball icon (making the layer invisible).
    If you rasterized everything and rendered the lens flare in pixels, well, then you probably need to re-render the text in the portions of the image where the effect.
    There is no magic "remove flare from pixels" tool.
    -Noel
    Mar 27, 2013 12:22 PM   in reply to Mustang813
    any chance we can see what you have?
    I mean if the effect is on the text layer, then can not you simply replace hte layer with the same text / font but no effect?
