shanebugbee
epub - table of contents -  entire book in each section??
Mar 27, 2013 11:09 AM
Tags: #cs4 #problem #toc #indesign #ebook #table #of #book #epub #contents
greetings all.
I'm at wits end... I'm producing an ebook in cs4 and when I output it to epub and check it in adobe digital edition, the entire book shows in each and every section/after each document.
I have tried to export it as one continuous document and I'm having the same issue.
so, after each and every place in the book I've applied paragraph styles, upon export, after each section, the entire book shows.
If I click on a section, that section will appear at the point in the book it should, along with the rest of the book.
what could be wrong?
I've taken notes, followed the tutorials, and have tried every combination of fixes I can think of… I've now exported this epub/book 37 times and have not found a fix.
any help would be greatly appreciated.
    Mar 27, 2013 11:29 AM   in reply to shanebugbee
    Is your book in just one ID document or in a Indesign book file?
    Mar 27, 2013 12:36 PM   in reply to shanebugbee
    Can you post a screenshot of the EPUB Export Options you are using for both the INDD and the INDB, the general and the advanced screens just to see if we can spot something in there?
    Mar 27, 2013 1:23 PM   in reply to shanebugbee
    Thank you. The advanced screen I mentioned is an option in the EPUB Export Options in ID CS6. The reason I mentioned the advance screen is that there is an option there "Split Document" and you can select "Do Not Split". I see you are using CS4. Hopefully some of the CS4 more experienced users will show up here and give you some advice.
