Problem with  uint
Mar 27, 2013 1:27 PM
I get an warning with this code, but I have the variable in binding already...
Warning: Data binding will not be able to detect assignments to "NewBatteryStatus"
[Bindable]
public var NewBatteryStatus:String;
          switch(NewBatteryStatus)
          case 1:
          NewBatteryStatus = "Red";
          break;
          case 2:
          NewBatteryStatus = "Green";
          break;
          default:
          NewBatteryStatus = "Yellow";
          break;
<s:Button id="Battery" x="791" y="513" width="124" height="46" label="Battery" fontSize="20" color= "{new uint(NewBatteryStatus)}"/>
    Mar 28, 2013 2:03 AM   in reply to fsoender
    You cannot bind styles.
    Ask yourself  these questions:
    Is NewBatteryStatus a) a string, or b)a numerical type and why am I trying to use it as both?
    Why am I trying to set what is expected to be a string value to be a uint?
    Why do I continue to ignore the camel-case convention for variables, starting my variable names with a lower case letter and class names with a capital, thereby writing code that will tend to confuse from the very start.
    If binding was working, why is my variable name described as New, when really it's just the current battery status? the variable name should be something like batteryStatus or currentBatteryStatus but not newBatteryStatus.
    Mar 28, 2013 8:59 AM   in reply to fsoender
    Binding doesn't work with styles.  Maybe some else can say exactly why, but styles aren't quite the same as normal attributes and I don't think the bind mechanism can work with anything but straightforward attributes. Styles have to be set explicitly.
    Look styles up.
    Mar 28, 2013 10:28 AM   in reply to pauland
    Just change this...
    "{(batteryStatus)}"
    to this...
    "{batteryStatus}"
    and add [Bindable] to the var declaration.
    This should work.
    [Bindable] public var batteryStatus:String;
    <s:Button id="Battery" x="795" y="514" width="124" height="46" label="Battery" fontSize="20" color= "{batteryStatus}"/>
    Apr 1, 2013 6:09 AM   in reply to fsoender
    You can't set it with binding. Set the style explicitly in code.
    battery.setStyle('color', 'red');
    Apr 1, 2013 8:46 AM   in reply to fsoender
    Please ignore this; it's just a test.
