amy20000
How to align intersected rectangles to a semi circle path?
Mar 27, 2013 3:16 PM
Hi all,
Does anybody can help me how to create in Illustrator something like that pictureabove?
I'm beginner in Illustrator ang I 've been trying to do that for a week. Sorry for language mistakes I'm not native English.
Many thanks for any help.
Amy
    Mar 27, 2013 3:37 PM   in reply to amy20000
    Draw your half circle (or whole circle, doesn’t matter).
    Make a guide of it (Cmd/Ctrl+5).
    Draw a rectangle and copy-drag it as many times as you need.
    Drag each rectangle down so that it snaps to the guide.
    It helps to have Smart Guides turned on while you do all of this.
    Here’s a picture of the job half done:
    Mar 28, 2013 2:00 PM   in reply to amy20000
    Use Effect > Distort & Transform > Transform (to create the 15 copies)
    Mar 28, 2013 3:23 PM   in reply to amy20000
    Amy,
    Elaborating on what Monika said, remember to use one less for number of copies, then Object>Expand, and Ungroup to work with each rectangle.
    And as Steve said, Smart Guides are your friends (you can even snap to a normal circle with their help).
    Mar 28, 2013 4:41 PM   in reply to amy20000
    Follow Jacob's advice in the message above. Select your rectangles and from the Object menu choose Expand (or Expand Appearance which ever is available) and then use Ungroup to make a series of rectangles which can be moved seperately.
    Mar 28, 2013 6:24 PM   in reply to amy20000
    How to create quickly 15 rectangles touching each other without using CTRL+F and doing it by hand?
    Copy-drag (drag with Option/Alt held down) the first time and then Cmd/Ctrl+D as many times as you need.
