PS CS6 Edit commands grayed out to copy / cut objects and layers?
Mar 27, 2013 5:32 PM
Tags: #photoshop #out #edit #paste #cut #copy #cs6 #unavailable #grayed
Why are my edit commands (copy and cut) grayed out / unavailable? When trying to copy a selected layer or object, all my editing commands are grayed out and unavailable. No idea why. Even if I convert something to a smart object, no joy. The only thing I seem to be able to select and copy/cut/paste is text in the text edit mode. makes no sense and is rendering PS unusable. How do I fix this?
Thanks.
    Mar 27, 2013 5:38 PM   in reply to KB8WFH
    Do you have a selection active (marching ants) when you use edit>copy or copy merged for instance on a pixel layer?
    Mar 27, 2013 6:55 PM   in reply to KB8WFH
    Your seeing the transform handles with the move tool.
    Try something like this:
    Open an image
    Click on the Rectangular Marquee Tool in the tool box
    (just below or to the left of the move tool in the tool box)
    (or press M on the keyboard)
    Draw a selection (marching ants)
    Edit>Copy
    Edit>Paste
    You should end up with a new layer with the copied contents from within the selection
  • Noel Carboni
    Dec 23, 2006
    Mar 27, 2013 9:27 PM   in reply to KB8WFH
    To add to that, to select an entire layer, press Control-A.
    -Noel
