Al@Alkar
"Cannot open resource file" when InDesign CS6 starts.
Mar 27, 2013 10:16 PM
I have an Intel Mac Pro running OS/X Snow Leopard.
When I open InDesign CS6 I get an error "Cannot open resource file", but there is no indication of what file it can't open.
When I click OK in the dialog box, InDesign opens and appears to be working.
I am concerned that this may cause a problem as I continue to use it.
Is there any way I can correct this issue?
I also have InDesign CS5.5 installed on the same Mac and it runs fine with no resource error.
    Mar 28, 2013 12:58 AM   in reply to Al@Alkar
    You'll get better answers on the ID forum. Could be anything....
    Mylenium
    Mar 28, 2013 1:34 PM   in reply to Al@Alkar
    Moving this discussion to the InDesign forum.  Al@Alkar have you tried removing and reinstalling InDesign?
    Mar 28, 2013 6:11 PM   in reply to Al@Alkar
    First thing I would try is trashing the preferences. See Replace Your Preferences
    Mar 29, 2013 1:08 AM   in reply to Al@Alkar
    The crash report might tell us more. Please post it on pastebin.com (not here), and then put a link to it here.
    Also, for troubleshooting purposes, please create a new user account on the computer and try using ID in that account.
    Mar 31, 2013 1:26 AM   in reply to Al@Alkar
    OK, that it works in a new account is diagnostic that there is a problem with the other account. Removing the prefs normaly will fix this, but in some cases you need to do a bit more.
    Log in on the original account again. Delete the prefs files manually again, then delete the files from the list you find at Adobe Forums: InDesign crashes at startup. Note that this list refers to the USER library.
    Also, go to http://www.adobe.com/support/downloads/detail.jsp?ftpID=5466 and download the InDesign 8.0.1 update and install it, then relaunch ID and for good measure use the keyboard shortcut to remove the prefs again.
