Parsa9
Color mode & settings for grayscale illustration to monochrome laser printer
Mar 27, 2013 11:25 PM
Tags: #illustrator #color #cmyk #mode #grayscale #monochrome #laser
Is there a best setting for the mode, color settings, and color profiles when printing a grayscale vector illustration to a monochrome laser printer? I am making vector maps, and right now they are mostly black line and black text with only the K values in CMYK. There are some gray tones—for example water areas are 10% K, with no C, M or Y. Would it make any difference if I used RGB mode values at 100% (255,255,255), or a rich black in CMYK (such as 40C, 30M, 30Y, 100K)?
I printed in K only at 1200dpi to a Generic Gray Gamma 2.2 profile, and it doesn't look too bad. There aren't many of the lines that are really jagged. I just wondered if there are better settings...
I'm using Mac OS 10.6, Illustrator CS6, and a Brother HL-5470DW monochrome laser printer.
Map image section:
    Mar 28, 2013 3:45 AM   in reply to Parsa9
    Parsa,
    Not really (to both).
    In some cases, using RGB with a PostScript (emulated) printer, or using CMYK with a non PostScript printer (through a PDF), you may get an unexpected outcome.
    Mar 28, 2013 11:39 AM   in reply to Parsa9
    I am, Steve.
    I believe you should use the BR-Script3 emulation driver if printing as an AI file (I just looked it up).
    Mar 30, 2013 2:58 AM   in reply to Parsa9
    You are welcome, Steve.
