bebe1134oaklandca
Trouble uploading site through an ftp client
Mar 27, 2013 11:44 PM
Tags: #error #internet #dreamweaver #style #html5 #ftp
Hi why is when I test my site through dreamweaver it looks great, but once I uploaded my files to my remote server my site is missing most of its information?
    Mar 28, 2013 12:05 AM   in reply to bebe1134oaklandca
    Depends on your Remote Site definition.
    Got a link to the website so we can take a look?
    Mar 28, 2013 6:08 AM   in reply to John Waller
    Are you uploading all the dependant files as well as the .html pages?
    Images, .css, .js and the rest all need to be uploaded as well. If you "Put" a page on your server, without also "Putting" the dependant files, your site will look broken.
    Another possibility is that you have not properly Defined a Site in DW and the links on your pages are pointing at your hard drive, rather than the server.
    Generally speaking, if you post a link to your page in the forum, someone will be able to help you out pretty quickly.
    Mar 28, 2013 7:39 AM   in reply to Jon Fritz II
    Another possibility is that you have not defined the Remote server properly and you are uploading your files to the wrong location.
    The only way to eliminate all of the alternate possibilities is to have a link to your page, and to know about how your site definition's fields read.
    Mar 28, 2013 9:21 AM   in reply to bebe1134oaklandca
    Depends on whether you have linked to those stylesheets correctly from your respective pages. Was there a reason to not have the other stylesheets in the folder as well? Can you verify if the relative path to the files is correct?
    Mar 28, 2013 9:24 AM   in reply to bebe1134oaklandca
    <img src="images/Column_1.jpg" width="300" height="350" alt="capital t_jefferison">
    This image is not found - it's either not uploaded or it's uploaded to the wrong place.
    Your menu is not seen because you have absolutely positioned it somewhere off the screen. Why use absolute positioning at all?
    Mar 28, 2013 9:52 AM   in reply to MurraySummers
    Aside from the above issues, and in addition to Murray's statement about positioning...
    Absolute positioning goes off the parent element if the parent has relative or absolute positioning itself, otherwise it goes off the browser window.
    You have defined your menu to be bottom:586px. Since it's parent is the relatively positioned "header" div, it is basically being told to "move up" 586px from the bottom of a 150px tall element at the top of your page. This pushes your menu is off the screen, above the page by a little over 400 pixels.
    DW may not understand what you're doing and simply refuses to display it as written.
    You can see it if you use FireFoxes 3D view when you Inspect Element.
    Mar 28, 2013 9:56 AM   in reply to Jon Fritz II
    Absoluote positioning will also key off of position:fixed, but not position:static. The rule is "nearest positioned ancestor".
    And locating something above the top of the viewport or to the left of the viewport is a very effective way to hide it without dropping scrollbars. Using right or bottom will generate scrollbars however.
    Mar 28, 2013 12:09 PM   in reply to bebe1134oaklandca
    Refresh your browser.
    This link appears to contain the newer content
    http://www.elisabethbschwarz.com/elisabethbschwarz/
    Nancy O.
    Mar 28, 2013 2:46 PM   in reply to bebe1134oaklandca
    This link does not appear to be template driven.
    http://www.elisabethbschwarz.com/elisabethbschwarz/index.html
    And here is the CSS file for that page (notice the path):
    http://www.elisabethbschwarz.com/elisabethbschwarz/styles/thrColLiq.cs s
    Everything is in a sub-folder off the domain root.  If this is not intentional, your site definition is messed up.
    Nancy O.
    Mar 28, 2013 3:20 PM   in reply to bebe1134oaklandca
    Let's see some screenshots of your Site Definition settings for Local and Remote.
    Nancy O.
    Mar 28, 2013 3:45 PM   in reply to bebe1134oaklandca
    I'm pretty sure HostGater requires you to upload your site files to a Root Directory called public_html.  If that's your hosting provider.
    See their support page
    http://support.hostgator.com/articles/cpanel/what-is-a-document-root-f older
    See my screenshot.  Change htdocs/ in my example to public_html/
    Nancy O.
    Mar 28, 2013 3:46 PM   in reply to bebe1134oaklandca
    The Root Directory field of your Remote Site definition is rarely blank.
    I suspect you're successfully connecting to the remote server but uploading to the folder immediately above the public website so you can never see what you've uploaded.
    You should enter into that field whatever your web host advised in their welcome email.
    Since you're on an Apache server, usually running Linux, normally it would be "public_html" (without the quotes). Try that to see if it worrks.
    Mar 29, 2013 11:02 AM   in reply to bebe1134oaklandca
    how do I define the title of my pages
    Look for the the <title> tags in your HTML code.
    <title> INSERT PAGE NAME HERE  </title>
    and the icon?
    Create a Favicon and upload it to your site's root folder (where your index page is located).
    http://alt-web.com/favicons.shtml
    Nancy O.
