TVF Ingo
Blackmagic only progressive?
Mar 28, 2013 4:55 AM
Tags: #output #xdcam #blackmagic #progressive #interlaced #decklink
i use the Blackmagic Decklink 2 with Premiere CS6 and the (HDMI) Videooutput is always progressive.
The Sequenzsettings are SONY XDCAM HD422 1080i/p and I use Sony XDCAM mxf files.
Decklink 2 works fine with Sony Vegas (progressive AND interlaced)
Ist there anywhere a special adjustment/setting neccasary?
thx!
    Mar 28, 2013 5:16 AM   in reply to TVF Ingo
    I don't know if this helps, but I use an Intensity pro card and it supports 1080 i/p . Sorry to ask the obvious, but I assume you are using interlaced video and an interlaced sequence.
    Mar 28, 2013 8:33 AM   in reply to TVF Ingo
    Not a BlackMagic user myself, but have helped set up a few systems. Besides Setup controls in Premiere, there is actually a separate panel with format/output options for BlackMagic, which I believe is found in Windows Control Panel. I forget what they call it. You would want the "1080i 59.94" setting. I think there is also a 60 option, but 59.94 is the right one (unless you are PAL user).
    Jeff Pulera
    Safe Harbor Computers
    Mar 29, 2013 11:51 AM   in reply to TVF Ingo
    That's confusing.  Sequences can't be set to i/p.  It's one or the other, so..which is yours?
    Apr 4, 2013 7:02 AM   in reply to TVF Ingo
    The BM-Cards support Interlace-Output...
    But this issue is a Software-Bug in CS6!
    I hope Adobe will fix this with the next release
    look here:
    http://forums.adobe.com/thread/1016269?start=0&tstart=0
