Choppy Transitions
Mar 28, 2013 5:36 AM
I am using FM 11 on Win 7 Pro 64-bit.
Whenever I run a published project, the transitons between slides are choppy.  Specifically, the transition starts, then the window blinks, then the transition completes.  It does not matter which transition I use, even NONE does the same thing.
Strangely, if I jump to the next slide through a command (custom button, Flash UI) before the end of the slide, its runs smoothly.  It is also fine if I have an interactive item on the screen that waits for user input before moving on.
Can anyone tell me why?  Better yet, how to make it a smooth transition?  Is there a file someplace that could be modified to control the transition?
Thanks.
