DanielMagz
Unable to launch After Effects CS6[Try] after installing (Stopped Working)
Mar 28, 2013 7:09 AM
Hi
So after installing. I tried to launch AE, then during initialization or loading, it will prompt a message "Has stopped working".
I was able to install AE CS6 and launch it properly on my laptop but I am having difficulties launching it on my desktop.
Desktop Specs
Laptop Specs
CPU: i5-3570k
GPU:
  • ASUS Radeon HD 7850
  • Intel HD 4000
note: Using Lucid Virtu.
Motherboard: Asrock Pro 3 z77
Ram: G.Skill Ripjaw X 8gb dual kit 1600mhz ddr3
Storage:
  • SSD: OCZ Vertex 4 128gb [OS]
  • HDD: 1tb Seagate Barracuda 7200rpm
OS: Windows 8 Pro 64-bit with media center
CPU:
Intel® Core™2 Solo processor SU3300/SU3500 (3 MB L2 cache, 1.20/1.40 GHz, 800 MHz FSB, 5.50 W), supporting Intel® 64 architecture
GPU:
Mobile Intel® GS45 Express Chipset with integrated 3D graphics, featuring Intel® Graphics Media Accelerator 4500MHD (Intel® GMA 4500MHD) with up to 1759 MB of Intel® Dynamic Video Memory Technology 5.0 (64 MB of dedicated video memory, up to 1695 MB of shared system memory), supporting Microsoft® DirectX® 10
RAM: 3gb of ddr3 1033mhz two module
Storage: 250gb WD Blue 5200 rpm HDD
OS: Windows 7 Ultimate 64-bit
Event Viewer LOG
Event 1
Event 2Event 3Event 4
Faulting application name: AfterFX.exe, version: 11.0.0.378, time stamp: 0x4f6d63ab
Faulting module name: atio6axx.dll, version: 6.14.10.12172, time stamp: 0x51423773
Exception code: 0xc0000005
Fault offset: 0x00000000011cb03d
Faulting process ID: 0x478
Faulting application start time: 0x01ce2baea1dc2c6a
Faulting application path: C:\Program Files\Adobe\Adobe After Effects CS6\Support Files\AfterFX.exe
Faulting module path: C:\WINDOWS\SYSTEM32\atio6axx.dll
Report ID: ee78c1ad-97a1-11e2-bf55-bc5ff44842d6
Faulting package full name:
Faulting application name: Adobe QT32 Server.exe, version: 6.0.0.0, time stamp: 0x4f6d5e4e
Faulting module name: QuickTime.qts_unloaded, version: 0.0.0.0, time stamp: 0x50890e53
Fault offset: 0x6ee2cce9
Faulting process ID: 0x103c
Faulting application start time: 0x01ce2baea914aa1d
Faulting application path: C:\Program Files\Adobe\Adobe After Effects CS6\Support Files\32\Adobe QT32 Server.exe
Faulting module path: QuickTime.qts
Report ID: e7563660-97a1-11e2-bf55-bc5ff44842d6
Faulting package-relative application ID:
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Faulting module path: unknown
Report ID: e7428280-97a1-11e2-bf55-bc5ff44842d6
Report ID: e708bde9-97a1-11e2-bf55-bc5ff44842d6
Here are some workaround/fix I tried to do:
  1. Uninstal and re-install.
  2. Uninstall, clear avery adobe product, remove paths and traces, relaunch, and then re-install.
  3. Same as step 2, with firewall turned off, Anti-virus removed.
  4. Run installation with Administrator rights.
  5. Launch program via Compatibility settines Vista, Vista SP1, Vista SP2, Windows 7
  6. All drivers are updated and reupdated.
  7. Re-installed all GPU drivers.
  8. Refreshed my Wndows 8 OS.
  9. Reformated my Windows 8 OS then Installed AE cs6.
  10. Installed AE on my F drive instead of C [C drive is an SSD and F Drive is an HDD]
I am able to see the AE CS6 splash screen but it will prompt a message "Has Stopped Working".
Other things to take note:
  • I am able to launch Renderer Machine without any issues.
  • I am also able to launch other Adobe Products that came along with AE CS6 try version.
  • Latest Quicktime version is installed.
    Mar 28, 2013 7:11 AM   in reply to DanielMagz
    I see that you're using After Effects CS6 (11.0.0). Install the updates so that you're using 11.0.2. Updating the application should be the first step in any troubleshooting process.
    See this page for details of updates and how to install them:
    http://bit.ly/lsrkmJ
    Mar 28, 2013 9:00 AM   in reply to DanielMagz
    Turn off your intel GPU in the BIOS/ EFI and only use the ATI/ AMD one.
    Mylenium
    Apr 1, 2013 8:49 PM   in reply to DanielMagz
    Hello everybody,
    I have the same issue DanielMagz had but the fix Mylenium suggested didn't work for me.
    I've been running Premiere Pro CS6 for 5 months smoothly, Intel GPU enabled. Installed After Effects trial 2 days ago and it won't even start before giving me the error message "0xc0000005".
    A first install was done from a folder downloaded 5 months ago from Adobe through the Application Manager. Since it didn't work I tried a fresh install directly through the Application Manager again. Didn't work either.
    My System:
    i7 3770K
    ASUS P8Z77-V Deluxe
    MSI GTX Geforce 660TI Power Edition
    GSkill DDR3 1600 - 8MB x 2
    Windows 7 Home Premium
    I have already tried the following (in that order) and none worked:
    1. Updating the BIOS.
    2. Updating the Geforce driver for the latest version, just released (since I was aware at least one of the driver update versions - don't remember which right now - didn't work with Premiere Pro, I was careful to keep a copy of my working driver to replace the new one if necessary. Premiere seems to be working with the new one so I din't switch back).
    3. Disabling the Intel GPU in the BIOS.
    4. Downloading and installing a fix from Microsoft for the "0xc0000005" error (which seems to occur in a variety of situations).
    It might be worth mentioning that I run Lucid Virtu although I don't think it's doing anything for Adobe software (I have also tried turning off its GPU virtualization to no avail. Is Lucid Virtu useful for Adobe soft at all? I have no intention of running games in this machine).
    I was strongly and urgently counting on After Effects to finish a project ASAP and most likely add it permanently to my bench, so it's quite disappointing.
    Also, it seemed strange to me that disabling the Intel GPU could be a solution, since part of the reason for its built (or so I'm told) and the choice of that motherboard in this system is the graphics features it has, to help the separate video card work with softs such as After Effects. Could anybody comment on that?
    Any help would be highly appreciated!
    Best regards.
