guy288
Cannot Rename in Bridge
Mar 28, 2013 7:58 AM
Tags: #problem #adobe #bridge #filename #cs6 #bridge_cs6
Suddenly I cannot rename or even delete RAW files downloaded from the camera card.  I have checked and have the latest versions of Bridge and Photoshop CS6.  I am running Windows 7 in 64 bit.  I have no problem opening the files through ACR.  If I look in Windows>Computer and alter the files names manually even by a adding one letter, I can then do all the normal things in Bridge - Batch Rename, Delete etc.  This is a real pain as I can shoot several hundred images in a day and I don't want to change each one manually in Windows.  Can someone help please?
    Mar 28, 2013 8:05 AM   in reply to guy288
    Closely check the camera time and date and make sure it is the same as computer time and date.  If picture "in the future" Bridge does not like it.
    Mar 28, 2013 8:43 AM   in reply to guy288
    If suddenly, meaning it worked yesterday, it did not work then I would reset preferences.  Hold down Ctrl key and start Bridge.  You will get a reset window with 3 options.
    Mar 28, 2013 2:06 PM   in reply to guy288
    Are you using a card reader?  They are more reliable than from the camera.  Try reading through different card readers if possible (in computer least realiable) and see it problem disappears.
    Mar 29, 2013 8:40 AM   in reply to guy288
    This sounds like a read/write permission issue.  Open up folder in Windows Explorer and right click on the file, look at Properties, and see what the permission levels are.
    Mar 29, 2013 2:00 PM   in reply to guy288
    You might try downloading direct from camera and see if that makes any difference.
