ndt.company
Error when caching data locally using LiveCycle Data Services
Mar 29, 2013 2:57 AM
Tags: #data #cache
Hi all,
I developing a mobile application support working offline. I using cache feature of LiveCycle Data Services.
This is my datasevice ( it has associate to others dataservice ) and autoSaveCache = true and cacheID = "xxx":
<destination id="expenseData">
          <properties>
                    <source>expense.ExpenseDataAssembler</source>
                    <scope>application</scope>
                    <item-class>expense.ExpenseData</item-class>
                    <metadata>
                              <identity property="id" />
              <one-to-many property="expenseItems" destination="expense-item" />
                    </metadata>
          </properties>
</destination>
when I run application in the first, it run nomarly but when I close and run it again , i get the errror message as below :
Error: Object instance needs an mx_internal::referencedIds property inorder to be managed: Object
          at mx.data.utils::Managed$/getReferencedIds()[C:\depot\DataServices\bran ches\milestone\adepds46_rc\frameworks\projects\data\src\mx\data\utils\ Managed.as:292]
          at mx.data::DataStore/restoreAssociations()[C:\depot\DataServices\branch es\milestone\adepds46_rc\frameworks\projects\data\src\mx\data\DataStor e.as:5010]
- The error message not showed when I remove line <one-to-many property="expenseItems" destination="expense-item" /> .
Please help me if you know about this problem.
Thanks so much.
