nickmantz
Anchor Point error offsetting type by 25 px...
Mar 29, 2013 4:31 PM
I am working in After Effects CS 6 (11.0.2.11) When using the text tool, my anchor point defaults to aprox. 25 pixels to the left of where is should be, regardless of how the text is justified. How can I fix this problem? Thank You!
    Mar 30, 2013 12:31 AM   in reply to nickmantz
    How do you verify this? What font? This could be perfectly normal based on how the font is designed and how its em box affects calculations for font sizes. otehr than that look for things like expanded spacing in th text panel or whether you parhaps ahve applied a text animator that shifts your characters around...
    Mylenium
    Mar 30, 2013 1:06 AM   in reply to nickmantz
    You need to reset your Paragraph panel. Your indent left margin is probably set to 25. You might also want to reset the Character panel. You'll find the reset option in the pull down menu you get when you click on the multiple line icon at the top right corner of the panel.
