Thijs1987
Need help with video-scroll
Mar 30, 2013 9:12 AM
Tags: #flash #video #3.0 #action_script_3 #flash_cs6 #mouse_position
Hello,
I need some help with a project. What I eventually want is that a webcam controls the mouse position and the mouse position
controls a video. But first I would like the part where the mouse position controls the video.
So if the mouse is on the left on your screen the video will be at the first frame and when you move you're mouse to
the right the video will play accordingly to the movement. and stop when the mouse is all the way to the right.
Effectivly the mouse scrolles through the video. It only needs to be on the x-axis.
I'm not that formilliar with flash so any help would be great
Thx!
Thijs
  • kglad
    Jul 21, 2002
    Mar 30, 2013 9:26 AM   in reply to Thijs1987
    by video, do you mean an flv or f4v?  if yes, are you playing the video in an flvplayback component?  or. using the netstream class?
  • kglad
    Jul 21, 2002
    Mar 30, 2013 11:26 AM   in reply to Thijs1987
    if flv_pb is your flvplayback component, you can use something like:
    import fl.video.MetadataEvent;
    import flash.events.MouseEvent;
    var duration:Number;
    var m,b:Number;
    var prevX:Number = 0;
    flv_pb.addEventListener(MetadataEvent.METADATA_RECEIVED,f);
    flv_pb.addEventListener(MouseEvent.MOUSE_MOVE,moveF);
    function moveF(e:MouseEvent):void{
        if(Math.abs(prevX-e.stageX)>100){  // you'll need to do something to prevent too frequent video seeks.
            flv_pb.seek(m*e.stageX+b);
            prevX = e.stageX;
    function f(e:MetadataEvent):void{
        paramF(0,0,stage.stageWidth,e.info.duration);
    function paramF(x1:Number,y1:Number,x2:Number,y2:Number):void{
        m = (y1-y2)/(x1-x2);
        b = y1-m*x1;
  • kglad
    Jul 21, 2002
    Mar 30, 2013 12:20 PM   in reply to Thijs1987
    do you have a skin for your component and is your component more than 100 px wide?  if yes, move the mouse over the skin (controls).
    if no, attach the listener to some other object.
  • kglad
    Jul 21, 2002
    Mar 30, 2013 2:53 PM   in reply to Thijs1987
    what you should do is designate a rectangle where users can use their mouse to scroll the video.  if that rectangle has instance name bar, you can use:
    var m,b:Number;
    var lastSeek:int = getTimer();
    bar.addEventListener(MouseEvent.MOUSE_MOVE,moveF);
    function f(e:MetadataEvent):void {
    function moveF(e:MouseEvent):void {
        if(getTimer()-lastSeek>1000){
            lastSeek = getTimer();
            flv_pb.play();
    function paramF(x1:Number,y1:Number,x2:Number,y2:Number):void {
        m = (y1 - y2) / (x1 - x2);
        b = y1 - m * x1;
  • kglad
    Jul 21, 2002
    Apr 1, 2013 12:06 PM   in reply to Thijs1987
    you're welcome.
    (but that looks like code for timeline embedded video which is not recommended.  the code i suggested is better.)
