PSE 11 Mac will not quit
Mar 30, 2013 10:10 AM
PSE 11 won't quit when I quit the application. It stays in memory and force quit shows it not responding. I can't shut my system down unless I force quit PSE 11 first.
Help
    Mar 30, 2013 10:32 AM   in reply to Danubius88
    Is this the editor or the organizer? What do you see in activity monitor? Are you saying you can't quit the process there?
    Mar 31, 2013 5:27 AM   in reply to Danubius88
    Go to the organizer preferences>media analysis and be sure that all the auto analyzer functions are turned off.
    Mar 31, 2013 8:26 AM   in reply to Danubius88
    Did you just add a large number of images to your organizer? Are you using the organizer at all?
    Mar 31, 2013 8:56 PM   in reply to Danubius88
    Then I'm confused by this part:
    Cannot quit the process there, must force quit.
    Why can't you stop the process in activity monitor? What happens when you try?
    Mar 31, 2013 10:16 PM   in reply to Danubius88
    Try again and this time choose to sample the process and post the sample here (copy/paste), please.
    Apr 3, 2013 5:02 PM   in reply to Danubius88
    Thanks for taking the time to come back and tell us what worked for you.
    Apr 3, 2013 5:21 PM   in reply to Danubius88
    Sure thing. Done.
    Apr 4, 2013 5:30 PM   in reply to Danubius88
    Have you tried repairing and optimizing your old catalog?
    And you don't use the welcome screen to start PSE, do you? You don't have it set to automatically open editor or organizer?
    Apr 4, 2013 6:09 PM   in reply to Danubius88
    Repair, then optimize.
    Apr 4, 2013 6:47 PM   in reply to Danubius88
    Do you mean that the organizer exits completely or just that you get the rainbow spinney?
    Apr 5, 2013 1:00 AM   in reply to Danubius88
    The tags which are there in image IPTC aren't there in database. They are actually a part of the image. If you want other images to have this tag or tag to appear in tag panel/with images in grid, you need to create the tag again.
    ~Andromeda
    Apr 8, 2013 1:23 AM   in reply to Danubius88
    Let me explain this using a scenario. Suppose you have a JPEG (from your camera). As of now it won't have any tag info into IPTC. You imported this image into Organizer. Now you created a tag and applied on this image. At this point of time the tag is only in PSE catalog db file. Also if you import the same image into another catalog, it won't have any tag info in its IPTC.
    To write a tag (from pse catalog db file) to image's IPTC, you need to use 'File->Write keyword tag and properties info to Photos' for PSE10 and previous versions (File->Save keyword tag to metadata info' in PSE11). Once you do this, the tag is now present in both catalog as well as in image IPTC info'. Now if you import this image into any other PSE catalog, it will show the tag written in its IPTC but not present in this new catalog'
    let me know if you need more clarification.
    ~Andromeda
    May 19, 2013 5:37 AM   in reply to Danubius88
    I had the same problem. Since I only need one photo editing suite, here's what I did. There might have been a conflict somewhere.
    1.  I uninstalled: Lightroom 4, The Gimp, PS CS2, Nikon NX2, PSE 8.
    2.  I went to "Utilities" and under disk maintenance repaired "Permissions"
    3. I shut down and re-booted.
    So far, so good.
