kayleighmurph
Exit Code 7 for Adobe Premier Elements 10
Mar 30, 2013 12:12 PM
Tags: #premeire_10
I cannot install Premier Elements 10 on my Mac. I have tried many times and it's getting frusterating. I keep recieving this message:
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 8 error(s), 7 warning(s)
WARNING: DW031: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 has been updated and has been selected for repair. The patch {FEA75AFB-4905-43BB-B1D5-5B44D681BFE7} Camera Profiles Installer_6.4_AdobeCameraRawProfile6.0All 6.4.0.0 will be uninstalled now.
----------- Payload: {68FE2517-2E45-4B03-8241-D0634F43878B} Smartsound1 1.0.0.0 -----------
ERROR: DW006: Apple Package failed to install successfully.
WARNING: DW036: Payload cannot be installed due to dependent operation failure
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Smartsound3: Install failed
ERROR: DW050:  - Photoshop Camera Raw for Elements 10: Install failed
ERROR: DW050:  - Smartsound1: Install failed
ERROR: DW050:  - Adobe Premiere Elements 10: Failed due to Language Pack installation failure
ERROR: DW050:  - Adobe Premiere Elements 10_LangPacken_US: Install failed
ERROR: DW050:  - Smartsound2: Install failed
I have a package that is for both the Photoshop and the Premiere Elements and I was able to download the Photoshop part but the Premier Elements part will not install all the way. Every time, it gets to about half way done and then it ejects the disk. I am using disk 3.. am I using the wrong disk? What's wrong? I am desperate.
  • kglad
    Jul 21, 2002
    Mar 30, 2013 12:25 PM   in reply to kayleighmurph
    try download the trial (after following all 7 steps): http://prodesigntools.com/photoshop-elements-10-direct-download-links- pse-premiere-pre.html
    and using your serial number to activate.
    if you see a dl error, you didn't follow all 7 steps.
    Apr 19, 2013 9:11 PM   in reply to kayleighmurph
    i have the same exact problem - installing Adobe Element 10 from disk; same exact screen dump as yours !
    I am also using disk #3 which is for Apple OS. get to about 60% and ejects the cd generating the errors.
    any way around this. can we download 10 from adobe site????
  • kglad
    Jul 21, 2002
    Apr 19, 2013 10:46 PM   in reply to imacabe1
    read message 1.
    Apr 19, 2013 11:10 PM   in reply to kglad
    Here is the solution from Adobe- Adobe patched a fix for this exact issue:
    http://www.adobe.com/support/downloads/detail.jsp?ftpID=5323
    The only problem you will encounter is that Apple will not let you run this fix- you will have to force it to overide the security setting; just read the directions and click on the question mark for the help. stop when you get to  INSTALL on the CD then run the adobe patch- it will get a little confusing but keep trying. i will confuse it more if i keep typing. good luck ! it will work !
