DashawnPD242
Save Changes to MySQL After Updating
Mar 30, 2013 12:42 PM
Tags: #air #flex-mobile #flex #xml #flex-4.6 #air3 #datagrid #4.5.1 #flex4.5 #flex4.6 #flashbuilder4.6 #xmlcollectionlist
I need a solution for saving text information after i update it. I am using a xml datagrid, which pulls the information. I use a popup window which allows me to edit the information. I can successfully update the xml datagrid from this popup window, but how do i save this updated information into MySQL Database? The update.php file executes perfect when using a php form.
My flex 4 code below:-
<mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml"
                                        xmlns:reservationsservice="services.reservationss ervice.*"
                                        close="ttlWndw2_close(event);" creationComplete="centerWindow()" layout="vertical"
                                        showCloseButton="true" title="Edit Booking">
          <mx:Form width="100%" height="100%">
                    <mx:FormItem label="Vehicle Type">
                              <mx:TextInput id="typeofvehicle" text="{dg.typeofvehicle}"/>
                    </mx:FormItem>
                    <mx:FormItem label="No. Of Vehicles" >
                              <mx:TextInput id="howmanyvehicles" text="{dg.howmanyvehicles}"/>
                    </mx:FormItem>
                    <mx:FormItem label="Chauffeur">
                              <mx:TextInput id="chauffeur" text="{dg.chauffeur}"/>
                    </mx:FormItem>
                    <mx:FormItem label="Payment Method" >
                              <mx:TextInput id="paymentmethod" text="{dg.paymentmethod}"/>
                    </mx:FormItem>
                    <mx:FormItem label="To">
                              <mx:TextInput id="goingto" text="{dg.goingto}"/>
                    </mx:FormItem>
                    <mx:FormItem label="From" >
                              <mx:TextInput id="goingfrom" text="{dg.goingfrom}"/>
                    </mx:FormItem>
                    <mx:FormItem label="Reception" >
                              <mx:TextInput id="reception" text="{dg.reception}"/>
                    </mx:FormItem>
                    <mx:FormItem label="Name of Passengers">
                              <mx:TextInput id="passengernames" text="{dg.passengernames}"/>
                    </mx:FormItem>
                    <mx:FormItem label="No. of Passengers">
                              <mx:TextInput id="numberofpassengers" text="{dg.numberofpassengers}"/>
                    </mx:FormItem>
                    <mx:FormItem label="Venue">
                              <mx:TextInput id="church" text="{dg.church}"/>
                    </mx:FormItem>
          </mx:Form>
          <mx:HBox width="100%">
                    <mx:Button id="savechanges" label="Save" click="SaveChanges(event);"/>
                    <mx:Button id="updatechanges" label="Update" click="UpDateChanges(event);"/>
                    <mx:Button label="Close" click="closeWindow()"/>
          </mx:HBox>
          <mx:Script>
                    <![CDATA[
                              import mx.controls.Alert;
                              import mx.core.IFlexDisplayObject;
                              import mx.events.CloseEvent;
                              import mx.managers.PopUpManager;
                              [Bindable]
            public var dg:Object;
                              private var objSend:Object = new Object;
                              protected function ttlWndw2_close(evt:CloseEvent):void {
                                        PopUpManager.removePopUp(evt.currentTarget as IFlexDisplayObject);
                              private function centerWindow():void {
                                        PopUpManager.centerPopUp(this);
                              private function closeWindow():void{
                                        PopUpManager.removePopUp(this);
                              protected function UpDateChanges(event:MouseEvent):void{
                                        // update mysql database
                                        dg.chauffeur = chauffeur.text;
                                        dg.howmanyvehicles = howmanyvehicles.text;
                                        dg.typeofvehicle = typeofvehicle.text;
                                        dg.paymentmethod = paymentmethod.text;
                                        dg.goingto = goingto.text;
                                        dg.goingfrom = goingfrom.text;
                                        dg.reception = reception.text;
                                        dg.passengernames = passengernames.text;
                                        dg.numberofpassengers = numberofpassengers.text;
                                        dg.church = church.text;
                                        updateReservationsResult.token = reservationsService.commit();
                              public function SaveChanges(event:MouseEvent):void{
                                        objSend.chauffeur = chauffeur.text;
                                        objSend.howmanyvehicles = howmanyvehicles.text;
                                        objSend.typeofvehicle = typeofvehicle.text;
                                        objSend.paymentmethod = paymentmethod.text;
                                        objSend.goingto = goingto.text;
                                        objSend.goingfrom = goingfrom.text;
                                        objSend.reception = reception.text;
                                        objSend.passengernames = passengernames.text;
                                        objSend.numberofpassengers = numberofpassengers.text;
                                        objSend.church = church.text;
                                        updateDatabase.send(objSend);
                                        // close the window
                                        closeWindow();
          </mx:Script>
          <mx:HTTPService url="http://localhost/update.php"
                                           id="updateDatabase"
                                           showBusyCursor="true"
                                           method="POST"
                                           resultFormat="text"
                                           result='Alert.show("Reservation Successfully Updated. Reservation May Take A Minute To Update")'
          <mx:CallResponder id="updateReservationsResult"/>
          <reservationsservice:ReservationsService id="reservationsService"
        fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)"
        showBusyCursor="true"/>
</mx:TitleWindow>
My PHP Code
<?php
//SQL Connection Info - update with your database, username & password
$host  = "localhost";
$username = "username";
$password = "databasepassword";
$database = "databasename";
$conn = mysql_connect($host, $username, $password);
        mysql_select_db($database) or die( mysql_error() );
$id = $_POST['id'];
$chauffeur = $_POST['chauffeur'];
$howmanyvehicles = $_POST['howmanyvehicles'];
$typeofvehicle = $_POST['typeofvehicle'];
$paymentmethod = $_POST['paymentmethod'];
$goingto = $_POST['goingto'];
$goingfrom = $_POST['goingfrom'];
$reception = $_POST['reception'];
$passengernames = $_POST['passengernames'];
$numberofpassengers = $_POST['numberofpassengers'];
$church = $_POST['church'];
$query = "UPDATE database SET chauffeur = '$chauffeur', howmanyvehicles = '$howmanyvehicles', typeofvehicle = '$typeofvehicle', paymentmethod = '$paymentmethod', goingto = '$goingto', goingfrom = '$goingfrom', reception = '$reception', passengernames = '$passengernames', numberofpassengers = '$numberofpassengers', church = '$church' WHERE id = $id";
mysql_query($query);
echo "Reservation Updated";
mysql_close();
    Apr 1, 2013 5:43 AM   in reply to DashawnPD242
    Have you tried adding a Fault function to the HTTPService to see what the error is?
