Transcoding presets
Mar 31, 2013 9:45 AM
  • Jean Paul Guillois
    Jun 13, 2011
    Mar 31, 2013 10:00 AM   in reply to Community Help
    Hello,
    When I want to import a preset that I saved before the pop-up menu does not tell in which directory it has been saved.
    How to locate the preset (*.epr) or where are located the customed presets? As an example: when I want to import a preset a pop-up window as the following comes out:
    But I do not know in which directory to look at...
    Thank you for any help.
    Jean-Paul
    Mar 31, 2013 10:42 AM   in reply to Jean Paul Guillois
    Click to save another preset, and write down the save location path
    Of course, that only works if you accepted the default when you saved before
    If you changed the default to some other location, you will simply have to search your hard drive
    Jun 13, 2011
    Apr 1, 2013 11:32 AM   in reply to John T Smith
    Hello John T Smith
    Thank you so much for the answer.
    I got it!
    I forgot to press the Alt key before clicking on .
    So it was not possible to actually export a file of type *.epr
    Sorry to have bothered you for nothing.
    Best regards,
    Jean-Paul
    Message was edited by: JP-49
    Apr 1, 2013 11:42 AM   in reply to Jean Paul Guillois
    It is true that using alt-click gives you the option of saving to a directory of your choosing, BUT the directory that opens has nothing to do with where the default save directory is.
    I think it is a type of "bug," that Encore is set up to save to a custom preset directory, but does not show that directory when you go to import the preset.
    I have not changed the default directory, which, for Windows 7, is "C:\Users\[user]\AppData\Roaming\Adobe\Adobe Encore\6.0\Presets."
    Jun 13, 2011
    Apr 4, 2013 8:27 AM   in reply to Stan Jones
    Thank you very much for your help.
    Thanks to your note I have found out where my presets are saved.
    The problem is that the search tool in Explorer does not work properly (or maybe I cannot master it). So I was not able to go to the proper directory.
    See you.
    Jean-Paul
