Andrew Mackinnon
Dreamweaver 5.5 uses 50% CPU and becomes unuseable
Mar 31, 2013 6:22 PM
As the heading says, my installation of Dreamweaver 5.5 has started to use 50% of the CPU time when any file is opened and effectively becomes unusable. I'm running Windows XP with SP3, Core2 CPU and 2GB RAM.  The program is also using quite a lot of memory (120,000K+).  I'm not having any problems with the other CS5.5 programs I use including Photoshop and Illustrator.
I use DW only occasionally and have run it on this computer for over a year without any problems.
I know that problems similar to this have been widely reported, so I have searched for a tried a wide range of fixes from Adobe and other sources, none of which have worked (for long).  These include:
Replicate problem with Dreamweaver templates rather than my own files.
All the steps in http://kb2.adobe.com/cps/405/kb405604.html including
Deleted cache file, WinFileCache-********.dat
Delete/restore preferences folder.
Disabled "Display External Files" in View menu.
Disabled "Enable Related Files" in Preferences.
Followed http://helpx.adobe.com/dreamweaver/kb/hang-opening-document-dreamweave r-cs5.html, adding registry entry ResolveRemoteURLToIPAddress FALSE
Remove and reinstall Dreamweaver.
Remove and reinstall all of CS5.5 and apply updates.
Move and test 'site' on another computer running the same version of DW (under Windows 7).
A few of these, notably disabled "Enable Related Files" worked initially but the problem returned when DW was closed and reopened, even though the item remained disabled.
The problem does not appear running in safe mode, which may be diagnostic of something but is not a fix.
The dream is turning into a nightmare.  I'm back to editing html using Notepad++! I'd be grateful for any suggestions.
Andrew
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Mar 31, 2013 9:25 PM   in reply to Andrew Mackinnon
    Disabling 'Enable Related Files' is a known fix from CS5 onwards. And ideally should remain intact even after DW is restarted.
    I'll see if I can ask a DW team-member to intervene here to help you.
    Mar 31, 2013 11:39 PM   in reply to Andrew Mackinnon
    Hi Andrew,
    I have asked support to get in touch with you. Do get back if you don't hear from us in the next 24 hours.
    Preran
    Apr 1, 2013 3:51 AM   in reply to Andrew Mackinnon
    Hi Andrew,     http://windows.microsoft.com/en-us/windows-8/upgrade-to-windows-8  (to see what is possible on your computer!)
    Instead of spoiling your time to get it work on a outdated OS it's maybe a better idea to change it to a up to date OS.
    Most duo cores are even 64bits! 2 GB ram is not a lot. To upgrade your computer cost peanuts compare to the trouble you
    will keep on experiencing with a system like your's.
    David
    Apr 1, 2013 8:26 PM   in reply to Andrew Mackinnon
    Hi Andrew,
    Thank you for sharing your workaround with us. Meanwhile, just in case, I have logged a bug for this issue.
    Preran
