kymlym1
Why does my new pdf colour differs from the old one?
Mar 31, 2013 9:30 PM
I am updating an old pdf document using Indesign. But I'm having problems when exporting the new PDF, the colours, especially the red doesn't print out correctly. How can I make sure the colours on the new document print out the same colours?
I placed the old PDF into Indesign, make some updates, save and exported it as a new PDF. but it doesn't save with the same colours. What can I do?
    Apr 1, 2013 3:36 AM   in reply to kymlym1
    It sounds like your color settings may be different in the two files, or that you are flattening transparency in the new export and should be using the RGB flattener space instead of the CMYK.
    Screen shots would help.
    Apr 2, 2013 6:18 AM   in reply to kymlym1
    We need those screen shots....
    Apr 3, 2013 1:40 AM   in reply to kymlym1
    Can you show us the actual PDFs? We might even need to see the .indd files.
    Apr 3, 2013 7:33 PM   in reply to kymlym1
    This is the color I get out put to a new PDF from the ID file...but with the missing PDF link the output color might be affected.
    Mike
    Edit, and this is what I see in your  G Guideline-draft-1.pdf file.
    Apr 4, 2013 4:04 AM   in reply to kymlym1
    It looks to me as if you've converted the spot color (pantone 186) to process during the export. In the original PDF the background is Pantone 186, and it's still spot in ID, but the second PDF is process. That's something that would have to have been done intentionally by clicking the Ink Manager button in the export dialog.
