Many line by line calculations
Apr 1, 2013 9:34 AM
Hi All,
I have a component with couple methods, each method is the result of query from the database.
I want to do some calculations after i get the data from the server. I am lokking for a solution with good performance because I have many calculations to do.
Code:
<cfset myObj = CreateObject("component", "cfcs.myComponent") />
<cfset firstQry = myObj.getFirstResult(arguments.A, arguments.B) />
<cfset secondQry = myObj.getSecondResult(arguments.A, arguments.B) />
Both query results have the same structure myID, myDesc, year_1, year2, year3
firstQry have 10 rows, how can I sum the years row 3 (myID = 3) and years row 5 (myID = 5) ?
and add the result of the calculation into firstQry as line 11 (new myID = 11).
secondQry have one row result.
How can I multiple the firstQry years row 4 (myID=4) with the secondQry years row 1 (only row myID = 1)?
and add the result into firstQry as line 12 (new myId =12).
I was thinking to use query of query but I wondering if it is a better way to do this.
Thanks in advance for your help.
Best,
    Apr 1, 2013 9:51 AM   in reply to jfb00
    Q of Q seems as good a way as any.
    Apr 1, 2013 7:27 PM   in reply to jfb00
    Have you considered putting the query inside the loop rather than the reverse?
    <cfloop from="1" to="3" index="y">
    <cfquery  name="insertQry" datasource="myDsn">
    INSERT INTO firstQuery (myID, myDesc, year_#y#)
    VALUES (...
    </cfquery>
    </cfloop>
    I don't think you can use a QoQ to insert (or update) records.  AFAIK you're just working with a cached copy of the data, so updating that doesn't really make sense.
    Apr 2, 2013 5:13 AM   in reply to jfb00
    To create a new query with more rows using Q of Q, make it a union query.
    select field1, field2
    from somequery
    union
    select Value1, Value2
    from somequery
