shabsxu
CS6 has stopped working
Apr 1, 2013 5:28 PM
Tags: #cs6 #windwos7
I've checked out some threads for other issues for this error.
Windows 7 64bit running CS6.  It has worked fine in the past, but all of a sudden, encountering this issue.  I've cleared the preferences and saved data manually, but no luck.
Windows Event viewer:
Faulting application name: InDesign.exe, version: 8.0.1.406, time stamp: 0x50335e39
Faulting module name: SUPPORT FOR JAVASCRIPT.RPLN, version: 8.0.0.370, time stamp: 0x4f72caab
Exception code: 0xc0000005
Fault offset: 0x00020334
Faulting process id: 0x1fec
Faulting application start time: 0x01ce2f384b0a9d44
Faulting application path: C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
Faulting module path: C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SUPPORT FOR JAVASCRIPT.RPLN
Report Id: bbfcd0ee-9b2b-11e2-aa8c-9c9fe439507d
    Apr 2, 2013 3:25 AM   in reply to shabsxu
    Check this,
    Have you run the 8.0.1 update for InDesign? if not, please update your application.
    Apr 2, 2013 9:27 AM   in reply to AMreso
    The error message shows that the exe file has been updated but that the faulting module was not properly updated. Sounds like it's time to uninstall, run the cleaner tool and reinstall.
    Apr 2, 2013 1:04 PM   in reply to shabsxu
    Apr 2, 2013 5:36 PM   in reply to Larry G. Schneider
    I just checked, and that particular plugin is not updated with the 8.0.1 patch, so that's not the problem (though reinstalling may still be in order).
    Apr 2, 2013 5:52 PM   in reply to Peter Spier
    Thanks for the work, Peter.
    Apr 2, 2013 5:54 PM   in reply to Larry G. Schneider
    No biggie. Just wish I had a clue what the root cause is.
    Apr 3, 2013 1:15 PM   in reply to shabsxu
    Unfortunately it's required for ID to run. I have a feeling Java may not be properly installed on the computer. Let's try re-registering the jscript.dll file with the OS.
    Go to the  Start button, then choose Run...
    In the command line field type regsvr32 jscript.dll (there's a space between the two parts), then click OK. You should get a success confirmation, and you can't hurt anything if it's already registered and you do it again.
    Apr 3, 2013 1:26 PM   in reply to shabsxu
    Yes, but we're getting outside the kind of advice I'm comfortable giving here. It's possible to screw things up even more.
    I think this probably qualifies as an installation issue, which means you should be able to call Adobe tech support and get some help from them for free (and they have access to more information than we do about what might be doing this).
