Specify general settings
Apr 1, 2013 9:39 PM
    Apr 1, 2013 9:39 PM   in reply to Community Help
    I need CMYK for printion.
    But font error occurs when publishing PDF to CMYK mode.
    Bold and Italic does not apply in korean font(gulim.ttc, batang.ttc).
    Most Korean font does not have bold.
    Apr 1, 2013 11:56 PM   in reply to shpark@latisglobal.com
    Tell us more about the font error – I'm not sure it would be related to the colour mode (CMYK).
    Apr 2, 2013 7:45 AM   in reply to shpark@latisglobal.com
    ".ttc" format fonts are a collection of TrueType fonts within a single file and the bold & italic members are probably within that file. Depending upon your operating system, locale setting and FrameMaker version, you may not have access to these sub-fonts within the collection.
    There also were issues with FM prior to the 10.0.2 patch version using the CMYK mode not properly supporting a variety of font types. I suspect TTC might also be one of these.
    More details on your operating system and FM version number might help ***** what your actual probelm might be.
    Apr 2, 2013 11:08 PM   in reply to Arnis Gubins
    Well I never – a colour mode screwing a font definition! FM errors are nothing if not imaginative
    Apr 4, 2013 2:41 AM   in reply to Niels Grundtvig Nielsen
    Thank you for yout quick response.
    Problems can be found in the attached images.
    0. FM version
    1. FM document character setting
    2. PDF color setup
    3. PDF output(RGB mode): no problem. same FM document.
    4. PDF output(CMYK mode): bold and italic error
    5. PDF font property
         a. RGB mode
         b. CMYK mode
    I select color mode in the "PDF Setup" When i create pdf.
    For some reason, CMYK mode was not bold and italic.
    In the pdf, font property have different expression.
    I don't know what went wrong.
    Apr 4, 2013 9:49 AM   in reply to shpark@latisglobal.com
    This might still be a problem with the CMYK mode in the SaveAsPDF option. The fixes in 10.0.2 addressed many known issues with TT-WGL and OpenType Pro fonts, but I don't think that TTC formats were ever properly tested. If you can get TTF versions (you'll end up with more discrete fonts), try using those as a workaround.
    Alternaively, try using the RGB mode to see if the fonts render coorrectly. If they do, then you can use Grafikhuset's PubliPDF tool to correct the RGB to CMYK for print production. See: http://design.grafikhuset.dk/index.php/kontakt/downloads/grafikhuset-p ubli-pdf for the freebie version download (it's freely available under an open source GPL v2 license now).
