Why wont dreamweaver connect to mysql?
Apr 2, 2013 5:08 AM
Ive created a MYSQL account and created a table, i then tried to insert  'data assist wizard search' to a php page in dreamweaver but it kept telling me i need to create a recordset first but when i try to do so no tables are found and there seems to be a problem with the mysql connection but i dont know what this message below means?
    Apr 2, 2013 5:19 AM   in reply to Ness_quick
    Where have you got your site folder located on your computer?
    Have you set up WAMP, XAMPP or MAMP?
    Is the site folder located within the htdocs folder of one of the above?
    Have you defined the testing server correctly in Dreamweaver?
    Apr 2, 2013 5:52 AM   in reply to Ness_quick
    If you don't have anything setup, where is the database?  Is it on your machine? On a remote host?
    Apr 2, 2013 6:22 AM   in reply to Ness_quick
    By default most hosts disallow remote connections.  Can you confirm with your host that you have setup mySQL to allow remote connections from your IP address?
    Also, just an FYI, DW typicaly looks for the testing server database first which are the programs osgood mentioned.  It's never advised to perform testing on live data.
    Apr 2, 2013 7:00 AM   in reply to Ness_quick
    You can't.  DW connects to the database server.  If it's not allowed, export your database, install WAMP/MAMP/XAMPP as suggested and import the data.  Then we can help you setup a testing server so DW can connect.
    Apr 2, 2013 9:10 AM   in reply to Ness_quick
    Ok, you said you had some data setup on the remote server.  Were you able to backup the database from the remote server?
