Still no joy... iOS compile for standard mode debug...
Apr 2, 2013 2:22 AM
Tags: #error #flash_builder #ios #standard_mode
I have a largish mobile / Flex project that I am compiling for debug / review / test.
In "ad hoc" release mode, it runs perfectly.
In "Fast" mode, it runs perfectly.
In "Standard" mode debug...
[SWF] gustavo_mobile_as_app.swf - 35,408,264 bytes after decompression
TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at en_US$Messages_properties/getContent()
          at mx.resources::ResourceBundle()[C:\svn\4.y\frameworks\projects\framewo rk\src\mx\resources\ResourceBundle.as:121]
          at en_US$Messages_properties()
          at mx.resources::ResourceManagerImpl/installCompiledResourceBundle()[E:\ dev\4.y\frameworks\projects\framework\src\mx\resources\ResourceManager Impl.as:396]
          at mx.resources::ResourceManagerImpl/installCompiledResourceBundles()[E: \dev\4.y\frameworks\projects\framework\src\mx\resources\ResourceManage rImpl.as:306]
          at mx.resources::ResourceManagerImpl/processInfo()[E:\dev\4.y\frameworks \projects\framework\src\mx\resources\ResourceManagerImpl.as:450]
          at mx.resources::ResourceManagerImpl()[E:\dev\4.y\frameworks\projects\fr amework\src\mx\resources\ResourceManagerImpl.as:133]
          at mx.resources::ResourceManager$/getInstance()[E:\dev\4.y\frameworks\pr ojects\framework\src\mx\resources\ResourceManager.as:117]
          at mx.styles::StyleManagerImpl()[E:\dev\4.y\frameworks\projects\framewor k\src\mx\styles\StyleManagerImpl.as:380]
          at _gustavo_mobile_as_app_FlexInit$/init()
          at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::kickOff()[E:\dev\4.y\frameworks\projects\framework\src\mx\managers\SystemMana ger.as:2815]
          at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::preloader_completeHandler()[E:\dev\4.y\frameworks\projects\framework\src\mx\managers\SystemMana ger.as:2723]
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.preloaders::Preloader/timerHandler()[E:\dev\4.y\frameworks\project s\framework\src\mx\preloaders\Preloader.as:542]
          at flash.utils::Timer/tick()
I have run through the code and there is an undefined reference for a Flex generated method. Because it happens so early on, it just kills the app and there is no way to work around it... yet I _NEED_ standard mode to test against as not all issues that occur occur in Fast mode...
Obviously, I have done nothing to modify core Flex functionality, and it works fine in the other compile modes, so can anybody direct me to a good way to resolve this?
Also, can anybody direct me to the appropriate bug base for Flex / Flash Builder? All the links I can find are either broken or won't let me in.
Regards,
Gaius
    Apr 8, 2013 1:04 AM   in reply to Gaius Coffey
    Hi Gaius,
    It's easy to feel abandoned by the Adobe team regarding the Flex SDK.  From last year they have moved to the Apache project and as far as I'm aware they are in charge of dealing with bugs in relation to the compiler.  (A shame, because I only just recently bought Flash Builder outright for 1000 dollars and there's absolutely NO support for features and bugs)  I've had problems in the past with the compiler/linker running out of JVM memory for a large application.  The Java SDK located inside of the Flash Builder directory has a config file where you can change the memory allocation as described here:
    http://stackoverflow.com/questions/2294268/how-can-i-increase-the-jvm- memory
    Though probably that isn't your problem.  Since Flex moved to Apache... if you have filled in the form and received the complimentary upgrade to Flash Builder 7.0, you can try upgrading your Flex SDK to Apache's version 4.9 as outlined here:
    http://stackoverflow.com/questions/14168790/installing-apache-flex-4-9 -inside-flashbuilder-4-7
    Best of luck!
    Jarrod
    Apr 8, 2013 1:55 AM   in reply to Gaius Coffey
    Hi Gaius,
    It is the linker that decides which functions make it into the final executable.  If there is a bug in the linker with your current Flex framework, there's a small chance the Apache team have already dealt with it.  If they have not then I'd suggest placing a bug report with the Apache Flex project. :-)
    http://issues.apache.org/jira/browse/FLEX
    Cheers,
    Jarrod
    Apr 8, 2013 2:06 AM   in reply to Gaius Coffey
    Once again, it's easy to feel abandoned by Adobe...  at least now you could be able to debug the Flex framework yourself... if you're game ;-)
    Apr 8, 2013 4:39 AM   in reply to Gaius Coffey
    Nice work - would have been some painful process of deduction.  Perhaps this is something worth shooting over to the Apache guys?
    Apr 8, 2013 6:06 AM   in reply to Gaius Coffey
    Good stuff.
