Pixie0413
Why won't cell phone pics load into Elements 11? why are photos reloading?
Apr 2, 2013 7:22 AM
Just got Elements 11 and had to reload my entire catalog (8000+ pics) losing 10 years worth of albums!@#$!  Key problems now (besides recreating albums): 1) cell phone pics won't load; response is "not supported" despite the fact hese are JPEG's, and 2) ALL pics on camera (600+) reloaded with "-1" extensions despite fact preferences indicates load new pics only.  Tried Adobe online help ~ suggestions were a joke (1 - copy all 95 cellphone pics and send to desktop; wound up with 95 icons.  2- create a new catalog and reload all pics off camera into that... not a solution to the problem).  Sure hope someone out there can help!
    Apr 2, 2013 2:13 PM   in reply to Pixie0413
    What happened to your last catalog? Were you upgrading from a previous version, or simply recreated the catalog you were using in PSE11? What OS are you on?
    1) Did these same photos work in your previous catalog? If so, have there been any changes to them since they previously worked?
    2) The "-1" is added when a file with the same name already exists in the same location the file has been copied to (to prevent overwritting the file). This means that likely the files were already on your computer and did not need to be imported directly from your camera again.
    (1 Sometimes in tech support the word "desktop" is used interchangably with "hard drive" (i.e. your "desktop" computer). If you've imported these files into the Organizer from this location, you can quickly move them to another location using the Orgaizner to reduce the clutter.
    2- This sounds like what you have already done. But things don't seem to be working properly, so this suggestion is to simply try again.
    Apr 3, 2013 7:37 AM   in reply to Pixie0413
    If your friend cleared you computer and installed Windows, then there should be nothing left from your previous computer. However, you mention "LG Octane", which sounds like you are talking about an external hard drive. Did you store you photos on this drive?
    If your Organizer catalog file was on the wiped drive, there should be no left over catalog with any files, new or old. So I'm not sure what you mean that there are old files in the catalog. There should only be what you've imported.
    Elements shouldn't be moving and duplicating files unless you tell it to. If you've imported these files from your device in the old catalog, Elements won't know that because that information is gone (it doesn't see the files on your hard drive until you import them). So if you are importing the files for the second time in a new catalog, that would easily explain the duplication.
    For email, you need Windows Live Mail (not Messenger, so not Skype either). This is downloaded as part of Windows Live Essentials.
