snoogiedoo
How to convert/ combine supported files (tif) in Acrobat
Apr 2, 2013 1:31 PM
Tags: #convert #combine_supported_files
This function is a tried and true tool I use "all the time" successfully in MS Windows Explorer. Now the option does not appear after selecting files. Must get it back!
    Apr 2, 2013 1:50 PM   in reply to snoogiedoo
    Hi snoogiedoo,
    You can use the Combine Feature in Acrobat for this.
    You can also open a Acrobat and drag all of the TIFF files into the Acrobat screen to create a PDF
    If you no longer are able to do this, try repairing Acrobat and check.
    Apr 2, 2013 5:08 PM   in reply to snoogiedoo
    Are you talking about the options to combine supported files in the context menu (right click)?
    Apr 3, 2013 12:11 PM   in reply to snoogiedoo
    Don't select too many files.
    Apr 3, 2013 2:53 PM   in reply to snoogiedoo
    What version of Acrobat are you running on Windows 7? Have you run an update lately?
    Like the others, I'd recommend the Combine feature which allows drag and drop and more control of the combining workflow (e.g., you can change the order before combining by dragging in the Combine Files dialog).
