How to programmatically set the endpoint in a flashbuilder created app
Apr 2, 2013 2:18 PM
Greetings,
I am running flashbuilder 4.5 for php premium.  I have created an application that read/writes to a postgresql database.
All is well.
Now for the unfun.   When I created the service in flashbuilder, I gave it a UNC for the gateway.php file.  Unfortuneately,
I don't know how to change the endpoint programmatically at run time.
My first thought was to use FlashVars in the html wrapper, then in my app in the Application creationComplete event handling code, I put
the following code:
var hostObj:Object = LoaderInfo(this.root.loaderInfo).parameters.myHost;
myService.endpoint = "http://" + hostObj.toString() + "/gateway.php";
that very much didn't work, and kinda screwed up my project.  Had to undo the html wrapper edit,  and the contentCreation code to get things
back in shape.
So, what is the correct way to programmatically set the endpoint?
Please note that the host file and dns will not solve my problem as many servers on a single network may be running my app.
thanks.
