Confused about color profile support in PNG
Apr 2, 2013 11:32 PM
Tags: #profile #png #icc #png_icc_profile
NOTE -- you have to hover over the image to see the real images.  The images embedded in the webpage have their profiles stripped -- just like photoshop does!  Interesting.
I ask a similar question on this before, but couldn't give a satisfactory demonstration of how photoshop doesn't support color profiles in png's.
But now I have a great one.
Picture A: this is with the correct color profile and displays correctly in firefox and probably other browsers -- also displays correctly on windows desktop and in large-icon view.  png-color-profile-test.png
Ok, anyone who doesn't believe me, grab that image and try to read it into photoshop...
I do, and get no warning on profile mismatch like I do on jpg's or tiff's:
photoshop strips the existing profile and adds sRGB which isn't the correct profile.
This is how photoshop transforms good colors into bad:
Completly screwed up.
I have had multiple people notice how my png saved images from photoshop had "off" or bad colors -- usually washed out in comparison w/my monitor profile.
I can get 'ok' results if I flatten the image and *convert* my existing profile to sRGB -- and I usually get
something that looks 'acceptable'...though the jpg's render in accurate color.
Basically, photoshop can't read or write png web images. and maintain color fidelity unless they have no profile.  Even if they have an sRGB profile, I usually get washed out looking pics if I don't strip it but let adobe convert it.
In googling for my own problem, I found references to this problem in Adobe Photoshop going back to 2002.
Why does adobe refuse to fix this?  It's horrible.
They could fix it with a file plugin for existing CS5-6 users, but it really needs to get fixed and Adobe needs to stop ignoring this problem.
:-(  I find this extra depressing because I prefer to distribute my pictures losslessly in png,  but with photoshop, I'm left with lossy jpegs to get accurate color reproduction.
    Apr 2, 2013 8:59 PM   in reply to Astara_
    png-color-profile-test.png opens just fine in Photoshop CS6, CS5, CS4, and CS3.
    And they save it with the profile and reopen it correctly as well.
    The profile might be stripped if you use a third party PNG plugin, or if you have your color settings set to ignore profiles.
  • Noel Carboni
    Dec 23, 2006
    Apr 2, 2013 9:54 PM   in reply to Chris Cox
    Don't I recall that File - Save As - PNG saves the profile while File - Save For Web - Png doesn't?
    -Noel
    Apr 2, 2013 10:27 PM   in reply to Noel Carboni
    There's no difference between the images in the post.
    Apr 2, 2013 11:31 PM   in reply to Noel Carboni
    Save For Web saves the profile if you tell it to save the profile (default to no profile, no metadata).
    And Save As... PNG saves the profile unless you disable it in the save dialog.
    Apr 3, 2013 3:55 AM   in reply to Chris Cox
    No, Save For Web does not save the profile in PNG, and when you choose PNG in the SFW dialog, the Embed Color Profile checkbox vanishes from the dialog.
    The OP will be working with a wider gamut than sRGB in Photoshop then using SFW to export to PNG and therefore with no profile. The browsers/viewers will assume the profile-lacking images are sRGB and therefore they will look washed-out in comparison to how they looked in Photoshop.
    Apr 3, 2013 10:10 AM   in reply to conroy
    SFW has offered ICC profiles in PNG for a while now.
    Are you using something much older than CS6?
    Apr 3, 2013 10:12 AM   in reply to Astara_
    No, Photoshop embeds the document profile.
    The only time it could embed a monitor profile is if you set your RGB workingspace to your monitor profile and disabled loading of existing profiles in documents.  (because embedding the monitor profile is usually a mistake)
    Apr 3, 2013 10:45 AM   in reply to Chris Cox
    I use CS6 and its SFW definitely does not embed a profile in PNG.
    You said in August 2012 that SFW does not embed the profile in PNG:
    This is my SFW plug-in version according to Help > System Info:
    Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
    Here is my SFW dialog with no Embed Color Profile checkbox when PNG-24 is the format:
    Apr 3, 2013 12:16 PM   in reply to conroy
    It was an oversight, fixed in the later releases of CS6.
    Apr 3, 2013 12:40 PM   in reply to Chris Cox
    Apr 3, 2013 12:40 PM   in reply to Astara_
    Astara_ wrote:
    How did the SFW thing even come up??
    SFW came up because its lack of profile embedding when exporting PNG (until a very recent version which you do not have) was one explanation for your problem of exported PNGs looking different to the original documents in Photoshop. Since we now know that you don't use SFW, nobody need mention it again in this thread.
  • Noel Carboni
    Dec 23, 2006
    Apr 3, 2013 12:57 PM   in reply to Chris Cox
    NO, it hasn't, not for perpetual license holders on Windows, who still only have the option of updating to 13.0.1.
    Apparently that bit of functionality was added to Photoshop CS6 in 13.1, as I do see it in 13.1.2.
    -Noel
    Apr 3, 2013 1:12 PM   in reply to Noel Carboni
    Hmm, I tried 13.0.4 - which probably means it was released with 13.0.2, and yes, Windows perpetual users are left out of that fix.  Sigh.  Even I'm getting confused about these versions.
    Apr 3, 2013 1:53 PM   in reply to Chris Cox
    Why  on earth would you save an image with a monitor profile?   Is anyone else going to see it?
  • Noel Carboni
    Dec 23, 2006
    Apr 3, 2013 9:15 PM   in reply to Chris Cox
    Can't say I blame you.
    It would be nice if Adobe would ultimately release all the bugfixes to PC users with perpetual licenses.
    -Noel
    Apr 3, 2013 11:42 PM   in reply to Noel Carboni
    But then you might never switch to Cloud Licensing, wouldn’t you?
