mussash9
Lagging streamed sounds
Apr 3, 2013 9:28 AM
Hi all,
I have an animation about 4 minutes long.  It's separated into 7 scenes.
When I made the sound, I exported the flash as a movie, and imported it into a video editor with a project of the same frame rate.  I made the sound, then exported segments of the sound that match the length of each scene.  Then I put each sound clip into the first frame of each scene.
It seems fine until scene 3 when the sound goes off synch.  This happens when I test the Movie.  However, when I test each individual scene, the sound seems right on track.
Does anyone know why this is happening?  Do you think I should try some other method of making the sound for the flash?
I appreciate it!
  • kglad
    Jul 21, 2002
    Apr 3, 2013 12:43 PM   in reply to mussash9
    you have 7 sound files that are each attached to the first frame of your 7 scenes?  if yes, assign the sync property of each sound to stream, not event.
  • kglad
    Jul 21, 2002
    Apr 4, 2013 5:00 AM   in reply to mussash9
    no, it's most likely a failure to assign all the sounds to stream but could be a problem with one of your sounds.
    to test, replace the scene 3 sound with the scene 1 sound.  assign its sync to stream and test.
    if there's no problem, open the scene 3 sound in a sound editor and resave using the same settings that were used for the scene 1 sound.
