Covering up ugly black desktop in full
Apr 3, 2013 4:44 PM
Background: Very casual Free PS2/Photoshop-Elements user on an infrequent basis and only as needed.
Objective: To put a single colored PS generated background behind my desktop picture which doesn't fill the screen. Looks like 2 fat ugly black bars on either side of the picture in question.  Time to make that black disappear into a much more colorful hue. 2 layers?
Summary: Background is the colored layer and the foreground is the picture concerned.
Easy I hope. Monitor is HD/Aspect Ratio is 16:9.
Please, How is that accomplished? That will help me to learn.
Thanks in advance.
    Apr 3, 2013 5:34 PM   in reply to Nikon D90 Gent II
    What operating system are you using?
    What is your screen resolution?
    On windows systems for example, you can right click on the desktop, click on Personalize (or Properties) and choose a picture and the way it fits on the screen.
    If say your screen resolution is 1920 x 1080, then in the photoshop elements editor you can use the Crop Tool to crop your picture to the screen resolution.
    Example with 1920 x 1080
    Enter the dimensions in the width and height boxes and then draw the crop tool out.
    Then save the picture as a jpeg with a quality between 8 and 10.
    Apr 3, 2013 5:39 PM   in reply to Nikon D90 Gent II
    Example of the saved picture as the desktop background:
  • 99jon
    Jan 6, 2010
    Apr 4, 2013 9:51 AM   in reply to Nikon D90 Gent II
    Open the image and use the menu:
    Image >> Resize >> Canvas Size
    Ad 10 cm to the width or a couple of inches and uncheck the right pointing anchors. Select a color of your choice and click OK to apply to the left of your original size image.
    Alternatively use:
    File >> New >> Blank file
    Choose a width and height and resolution 72 and choose a background color.
    Click OK and then open your image.
    Drag your image from the photo bin and drop it on top of the blank file. Select the move tool and drag the corner handles to scale and then move into an appropriate position.
    Apr 4, 2013 10:37 AM   in reply to Nikon D90 Gent II
    Ah, my mistake for not reading your post closely enough.
    It still helps to know your screen resolution as just using 16:9 ratio won't necessarily fill the whole desktop  even with a colored border.
    What version of photoshop elements do you have?
    I guess you have photoshop cs2 as well?
    Also, what operating system are you using?
    Apr 4, 2013 11:14 AM   in reply to Nikon D90 Gent II
    Here's another way:
    1. Open your picture and double click on the background layer in the layers panel to make the layer a regular layer
    2. Go to Image>Resize>Canvas Size and enter your screen resolution in the width and height boxes with relative unchecked
    3. Add a new color fill layer and move the color fill layer (Solid Color) below the picture by dragging on the color fill layer in the layers panel
    4. Double click on the color fill icon in the layers panel to change the background color.
        You can also use the eyedrooper to sample colors from your image while the color picker dialog is open.
    5. Save your picture as a jpeg and set your desktop background using your saved picture.
