333Aragon333
How do you create a macro for a repetitive function in Premier Elements 11?
Apr 3, 2013 6:18 PM
How do you create a macro to perform a repetitive function?
    Apr 3, 2013 6:50 PM   in reply to 333Aragon333
    Welcome to the forum.
    PrE does not support scripting, just as PrPro does not.
    However, if one uses special programs, they might be able to create macros, but then PrE will need to be run in that program's shell.
    Good luck, and what do you wish to script?
    Apr 4, 2013 10:36 AM   in reply to 333Aragon333
    For the Video Transitions, you can set the Default Video Transition, then Select all of the Video Clips in the Timeline (drag the Cursor to "lasso" them), Rt-click and choose Apply Default Transition.
    Not sure what you mean by adding the default Audio. Do you mean to also apply the Default Audio Transitions, or something else?
    Good luck, and thanks for that info,
    Apr 4, 2013 10:50 AM   in reply to 333Aragon333
    Good luck, and if you have trouble "lassoing" the Clips, you can add to a Selection by holding down the Shift key and clicking on multiple Clips. I find that zooming out on the Timeline, allows me to lasso most Clips on the same Video Track. It takes some practice with longer Timelines, but works well.
