luctantemboy
How to draw following letter as a Vector image!
Apr 5, 2013 1:55 AM
Tags: #cs6
Hello Friends,
I've posted this earlier but unfortunately I dint got any solutions. So I ask here again.
Task:  I want to design letter S like following image with sharp edges and in vector, So that I will not loose quality if it made into any big size.
Please note that I'm a newbie and I need a step by step procedure so that it will be helpful...and I'll be glad for ur time.
Edit:  My OS : Windows 8
Illustrator Version: CS6
    Apr 5, 2013 2:31 AM   in reply to luctantemboy
    Draw 3 straight, horizontal rectangles.
    Space them accordingly.
    Select the Free Transform Tool.
    Select the top rectangle, click the left side handle, THEN hold down the Ctrl key and drag downward.
    Select the bottom rectnagle, click the right side handle, THEN hold down the Ctrl key and drag upward.
    Select the middle rectangle, click either side handle, THEN hold down the Ctrl AND Alt keys and drag up or down.
    Once you have them lined up like you want, select all Pathfinder > Unite.
    Apr 5, 2013 2:32 AM   in reply to luctantemboy
    Please visit this link to know about vector artwork in illustrator CS6 in detail.
    http://help.adobe.com/en_US/illustrator/cs/using/WS714a382cdf7d304e7e0 7d0100196cbc5f-6269a.html
    If you able to do it please let us know.
    Apr 5, 2013 4:17 AM   in reply to luctantemboy
    1) Pen tool: Draw your zig-zag.
    2) Object > Expand.
    3) Pen tool: draw a line that cuts off stroke ends and sharp corners.
    4) Select that line only and Object > Path > Divide Objects Below.
    5) Delete the bits you don’t need.
    Apr 5, 2013 9:13 AM   in reply to luctantemboy
    After 2nd step , If I use pentool , I get expanded lines, How to get out of it ??
    You don’t want to get out of it. Why do you think I told you to expand the stroke?
    Your destination is a filled path, not a stroked one.
    Apr 9, 2013 10:05 AM   in reply to luctantemboy
    Select them and press Delete.
    Apr 9, 2013 2:05 PM   in reply to luctantemboy
    Direct select them and either Backspace or Edit > Clear.
    Backspace is quicker.
    Apr 9, 2013 2:56 PM   in reply to luctantemboy
    This is an animated gif image. Click the image to see the animation......
    Apr 9, 2013 4:15 PM   in reply to [scott w]
    All very clever but it doesn’t look a bit like the original.
    Notice that the top part is narrower than the bottom part.
    Which is why the cutting path in my step (3) was not a simple rectangle.
    Apr 9, 2013 11:07 PM   in reply to Steve Fairbairn
    Come one Steve, you and I both know the original rectangles can be changed to match whatever shape or position is needed. You're simply being silly now.
    Apr 10, 2013 3:41 AM   in reply to luctantemboy
    Nglish plz.
    Obviously you must start off with the correct stroke width.
    I did this by tracing your original with the Pen tool and adjusting the stroke width until it was right.
    I trashed my drawing but I seem to remember that the stroke weight was 12 pt.
    Once you’ve done that the rest is plain sailing.
    The cutting line might just as well have been a clipping mask except that for creating a letter form you need a simple closed path.
    This is why I chose the more destructive ‘Divide Objects Below’ method.
    Maybe for your purpose you might like to use a clipping mask until you’ve got things right and then use the masking path for dividing.
    I’m not sure why you have trouble expanding the original stroke.
    Object > Expand... Stroke or Object > Path > Outline Stroke will both get you there.
    Apr 10, 2013 3:29 AM   in reply to [scott w]
    No, not at all.
    It can be quite troublesome adjusting things afterwards if the lines come in from different directions.
    Simply dragging multiple points will result in varying stroke widths.
    Apr 19, 2013 4:50 AM   in reply to luctantemboy
    If you are using the ‘Divide Objects Below’ method you must only select the cutting line.
    Everything below it will be cut.
    Apr 19, 2013 2:37 PM   in reply to luctantemboy
    or, draw three red rectangles:
    use the white arrow (direct select tool) and click on the two left corners of the top rectangle:
    press the down arrow on your keyboard or click and drag with your mouse to bring those two corners down to the second line:
    do the same to the right side of the second rectangle. then do the same to the left side of the bottom rectangle:
    Then press ctrl+A and then ctrl+G to group them as one object.
    EDIT: sorry Scott, i didn't watch your clip until after i posted....
