Hanlie_Robohelp
Importing DocBook Content to Robohelp 10 failed to import
Apr 5, 2013 2:01 AM
Hi There - we are creating rich content in Confluence (text, videos and images), we then export to DocBook. I would now like to import the DocBook(XML) content into Robohelp but it failed to import. Is there someone that can assist me with this process. The output should then be generated as a .chm or HTML Help.
    Apr 5, 2013 8:54 PM   in reply to Hanlie_Robohelp
    Hi there
    I found the following snippet in the thread linked farther down. Maybe it will help?
    If you want to create a web-based help FROM DocBook, then you have some choices:
    1. Use the DocBook xsls to create HTML Help output (i.e. the .hhp and .hhc files and the html files), then open the hhp in RoboHELP and generate WebHelp from that. I used this trick for years, but it was annoying to have one manual step in an otherwise automatic build process.
    Click here to view the full thread
    Hope this helps a tad... Rick
