Stanfield_A
Streaming Problems (End of stream & AsyncErrorEvent)
Apr 5, 2013 7:18 AM
Tags: #flash #code #streaming_video #video_playback #netstream.play.stopped #end_of_stream #asyncerrorevent #flash.net.netstream #onmetadata #2044 #2095
Hey,
Here's the section that I need help with:
My current output:
  • Playback connection OK
  • Error #2044: Unhandled AsyncErrorEvent:. text=Error #2095: flash.net.NetStream was unable to invoke callback onMetaData. error=ReferenceError: Error #1069: Property onMetaData not found on flash.net.NetStream and there is no default value.
          at MethodInfo-14()
          at MethodInfo-14()
I addition to this I need to find when the stream ends.
Cheers.
  • kglad
    Jul 21, 2002
    Apr 5, 2013 7:27 AM   in reply to Stanfield_A
    create an onMetaData function to handle the metadata and use a listener to detect the end of your stream, either by adding a cuepoint, checking duration or using a netstatus change event.
  • kglad
    Jul 21, 2002
    Apr 5, 2013 9:42 AM   in reply to Stanfield_A
    you should use something like;
    var duration:Number;
    var ns:NetStream=new NetStream(your_netconnection);
    ns.addEventListener(NetStatusEvent.NET_STATUS,statusChangeF);  // you'll need to import the NetStatusEvent and you may need to use the full path like flash.events.NetStatusEvent.NET_STATUS
    ns.client=this;
    function onMetaData(eobj:Object):void{
    for(var s:String in eobj){
    trace(s,eobj[s]);
    duration = eobj.duration;
    function statusChangeF(e:NetStatusEvent):void{
    switch (event.info.code){
            case "NetStream.Play.Stop":
    if(ns.time==duration){
    // stream completed.  do whatever
                break;
  • kglad
    Jul 21, 2002
    Apr 5, 2013 11:55 AM   in reply to Stanfield_A
    that's not even close to the code i suggested.
    to start, never nest named functions.  under no circumstance will that work.
    next, your netconnection client definition is screwy.
    unnest all your functions,  use the code i suggested and add what ever you want to it like
    function onBWDone(...rest):void{
    //whatever
    p.s. paste your code into this forum, don't use a link to your code.  years from now, others checking this thread won't be able to follow it.
