kruserm
Can Premiere do this?
Apr 5, 2013 10:56 AM
Tags: #help #video #premiere #elements #11 #premiere_elements
I have PE11 and I am trying to figure out how to do some of the things in this video with PE11, http://www.youtube.com/watch?v=bBJ4M2sWAKk.  Starting at 1:52-2:00 where you get that video skip effect.  Also at 2:40 where you have a ghost effect and then come back and pick the ghost.  Is it possible to do these same effects with PE11, if so how?
    Apr 5, 2013 6:54 PM   in reply to kruserm
    Yes, Premiere Elements can do the "skipping" thing. That's just slow motion with a couple of cuts in it.
    The second effect is a rather sophisticated version of what you can do with Premiere Elements' Ghost effect. (It was probably done in After Effects, so it's a bit higher end. But you can do something very similar in Premiere Elements.) Though it could simply be several videos layered on top of one another with 50% opacity.
    Dec 2, 2013 1:55 PM   in reply to kruserm
    Hey guys,
    i am trying hard with those ghost-effects shown in the video with my premiere elements 12 - this effect is also referred to as echo effect or frame freeze effect and is really nice variation is applied here: http://www.youtube.com/watch?v=EPr32OYuEmo at 1:40 and 2:58.
    Is this effect possible in PE 12, too and by the way, is there any tutorial you know about which shows how to do these effects in PE?
    Dec 2, 2013 2:14 PM   in reply to henner_mo
    That looks a lot like the Posterize Time effect.
    Dec 2, 2013 2:37 PM   in reply to Steve Grisetti
    From the video authors info:
    Editing Software: Sony Vegas Pro 10 (recorded in 1080p - 60fps in protune)
    Cheers,
    Neale
    If this post or another user's post resolves the original issue, please mark the posts as correct and/or helpful accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
    Dec 3, 2013 3:37 AM   in reply to nealeh
    This fact does not say whether Premiere Elements can do this - i cannot imagine that this effect is unique to the Sony Software, is it?!
    Dec 3, 2013 3:41 AM   in reply to Steve Grisetti
    The posterize time effect - as i know - enables you to alter the framerate and i could not find it in the elements version of premiere either. Could  you please explain how an altered framerate explains the effect in the Ken Block video?
    thank you for your help!
    Dec 3, 2013 5:41 AM   in reply to henner_mo
    No. Posterize Time has nothing to do with the frame rate.
    Have you tried it? It creates a visual echo effect, similar to the one in the video. (The effect in the video was likely produced by a more sophisticated program like After Effects, and may well involve a complicated layering and matting of several videos.)
    Dec 3, 2013 7:12 AM   in reply to Steve Grisetti
    ok, i will take a closer look at it.
    You are right - after effects is perfectly suitable for such effects, unfortunately i do not have acces to this software, thats why i was looking for some kind of a workaround in premiere elements in the first place.
    thank you for your help anyway!
    Dec 3, 2013 7:42 AM   in reply to Steve Grisetti
    SG
    Could you elaborate on your statement "Posterize Time has nothing to do with the frame rate."?
    To the contrary, it would appears that it does. According to the Premiere Elements Effects Reference
    Posterize Time
    The Posterize Time effect changes the frame rate of a clip to one you choose. You can use it to slow a 30-fps clip to 24 fps, for example, to give it the look of film, slow it to 18 fps to simulate the jerkiness of old home movies, or slow it even further to give it a strobe effect.
    And according to the version 11 Applied Effects/Applied Effects Palette/Posterize adjustment panel once this effect is applied to a clip....
    In the books that you have written, going back to version 2, you seem to say that Posterize Time allow you to change frame rate. So, what is different now that makes you change your view of that function.
    Here I am not addressing how it works or how well it works, just the question of the Adobe description including frame rate adjust.
    Thanks.
    ATR
