Brighton Lance
Getting a semi-transparent graphic onto a spot plate in InDesign CS6
Apr 5, 2013 12:19 PM
I'm struggling to get elements of a design onto the fifth colour plate in my InDesign file. Example is shown below. I have made a number of rough-edged strips that retain an element of semi-transparency along their edges (so that the background shows through slightly and gives a brushed/painted on effect). The client needs these elements to be on a fifth plate, Pantone 1385.
I have tried making the graphic as a greyscale psd and as a greyscale tiff with transparency included, but I can't seem to select within InDesign using the content tool and making it on the fifth plate in my ID palette.
Have done it as a CMYK psd for time being on example below just to allow me to show the client as a visual.
Can anyone help me? I have also (briefly) explored channels in Photoshop as well but can't make and headway there too. Is there a simple solution?
Many thanks for any advice.
    Apr 5, 2013 12:59 PM   in reply to Brighton Lance
    You can select the content with the direct selection tool of an image and color it with any color when:
    1. The image has NO LAYERS in Photoshop (onl Background)
    2. The image is either bitmap (1-bit-color) or greyscale
    It doe not work with layered images, cmyk image or rgb images.
    It works only with psd and tiff, not with jpg or png.
    Apr 5, 2013 1:04 PM   in reply to Brighton Lance
    Yes, Will's method would not work with transparency.
    Start with a grayscale image in Photoshop and create a spot color channel with the Channels panel. This method should work with transparency.
    Do a Google search on "Photoshop create spot color channel."
    Then save the spot channel image as a PSD and place it into InDesign, and you should have your fifth color.
  • Rob Day
    Oct 16, 2007
    Apr 5, 2013 1:46 PM   in reply to Brighton Lance
    Thanks for reply, but I think this loses me all transparency?
    Make your grayscale file a transparent Monotone like this:
    In ID fill the background of the image frame with black:
    Apr 5, 2013 9:38 PM   in reply to Brighton Lance
    Maybe I am missing something. Possible after a couple screwdrivers...
    Why not make a monotone using your Pantone color in PS and simply load it into ID?
    Take care, Mike
  • Rob Day
    Oct 16, 2007
    Apr 8, 2013 3:48 AM   in reply to Brighton Lance
    You're in the wrong dialog. Open your transparent grayscale file and choose Image>Mode>Duotone then set the Type to Monotone and click on the color patch to choose your color. See the first capture in #4
    Apr 8, 2013 6:14 AM   in reply to Brighton Lance
    Mike
