jvels
Delete part of shape/layer
Apr 5, 2013 1:49 PM
Tags: #layer #elements_11
Hi
I have this in Elements 11:
I would like to delete/remove the part of layer/shape 10 there outside of layer/shape9. How do I do that?
Best Regards
Jesper Vels
  • 99jon
    Jan 6, 2010
    Apr 5, 2013 2:33 PM   in reply to jvels
    Probably easiest to make a selection around the green area and press Ctrl+J to place it on its own transparent layer.
    You can then switch off the layers below by clicking on the eye symbols as required.
    EDIT
    I should have said if it’s almost your final deign it is easiest to work on a flattened image re-saved under a new file name (Layer >> Flatten Image) and then make your selection.
    If you intend to make further design changes then you should try a layer mask on layer 10 and paint out the unwanted area with a brush and foreground color set to black. You can switch to white, to correct, if you make a mistake.
    Apr 5, 2013 7:38 PM   in reply to jvels
    Perhaps loading a selection of Shape 9 and then adding a layer mask to Shape 10 would work.
    (Ctrl click on the layer Shape 9 layer thumbnail in the layers panel to get the selection)
    Also, if you move the Shape 9 layer below the shape 10 layer and create a clipping mask, that might work as well.
    (after moving shape 9, make shape 10 the active layer and press Ctrl+G to create the clipping mask)
    (from the menu Layer>Create Clipping Mask)
    Apr 6, 2013 4:37 AM   in reply to jvels
    Ctrl-click Shape 9 in the Layers Palette to select just the shape.
    Invert the selection.
    Activate Shape 10 and delete the selection.
