pdf to word conversion: corrupt equations
Apr 6, 2013 5:46 AM
Tags: #word #equations #convert
I had a word document (doc format) full with difficult equations. I converted it to pdf format.
At this stage everything looked perfect.
Then I needed to convert it back from pdf to doc.
Now, this time most of the equations looked awfully.
So the resulting word document is completely unusable.
(Not to mention the annoying fact that the equations are no more in the original editable format.)
Please, suggest some solution, I need an assistance urgently.
See a screenshot for example below.
This was the promise:
...and this is the truth:
- No time saving, as complete retyping needed for the equations.
- In the exported word document the equations are not editable.
- No page and font attributes maintained for equations.
I got here by the link below:
If you have a technical problem using your product and need immediate assistance, please contact us.
https://www.adobe.com/cfusion/support/index.cfm?event=portal&loc=en_us
I am still hopelessly waiting for the "immediate assistance" for more than 4 hours.
    Apr 6, 2013 7:18 AM   in reply to cserezol
    Did you save the original word file?
    You should never ever depend upon on conversion tool (whether standalone or built into Acrobat) to convert from PDF back to word.
    As long as its text and the pdf was created from text. it usually comes across okay. even then you have to turn on The ¶ button and  remove many cariage returns in sentences  To get it back to being an editable word Document.  The converter is meant for times when you given a PDF and not the original and you need to make serious changes. The only way then is to create a Word file from it. If it’s a scanned document to PDF it won't work because it’s a picture not text.
    1. My suggestion would be print a copy of the PDF.
    2. Convert to word
    3. Completely wipe out the line lines of equations and retype them  in Word.
    4. Once you get everything Perfected, make you corrections Then save the document as  either a DOC or DOCX file for safe keeping.
    Never ever depend on the ability to convert back from PDF and not save the original.  Makes no difference if your using a Windows Machine or a Mac. Never depend on a Converter they are for emergency situtaions only.
    Apr 6, 2013 8:52 AM   in reply to cserezol
    Have you tried converting the Document then just erasing the equations and retyping those in.  The text part of the document should convert fine.
    Apr 6, 2013 12:27 PM   in reply to cserezol
    A lot also depends on the way the PDF was created. To get the word locations and layout correct, you need to use PDF maker (the create PDF option in WORD) to create the PDF. That adds tags that can be used to backup. I will help with equations too, but not very much. You are asking for something to back out the equations that Acrobat does not recognize as equations. Acrobat may structure some of it based on the equation being a graphic of sorts (depends on the version of WORD and the equation editor used -- WORD or MathType). In any case, I would go back to the lab or where ever and try to get the original WORD document for the revisions. An alternative would be to convert to WORD and then edit ONLY those pages that need revision and then cut-and-paste when you are back in the lab.
    With the results you are seeing and your feelings about the results, it is a good thing you only paid $19.97 and not the full cost of Acrobat. You would still be disappointed and very mad. Actually, AA XI does the best I have ever seen for conversion back to WORD, but it still has a lot of issues such as equations, and they may never be totally solved.
    You can also use the snapshot tool in Acrobat to pull a graphic of the equations back into WORD. However, you are not dealing with Acrobat and so you do not have the tools.
