Greyed out input fields in InDesign
Apr 6, 2013 12:51 PM
Tags: #indesign #cs6
First, some information: I'm running Adobe CS6 on Mac OSX 10.8.3.
Recently, InDesign stopped displaying the menu fields for any sort of input within the application. For example, when creating a document, I can't input a width or height or page numbers. Inside a document, I can't change the font size or type. Even when exporting as a PDF, the prompt box's won't allow me to change any of the fields.
I've restarted InDesign and my computer, and after that didn't work, I reinstalled the application, but the problem still remains. I don't know what to fix or what is even broken. I've never heard of this problem happening to anyone, and from searching around on the web, it seems pretty rare.
Any help or suggestions would be very much appreciated.
    Apr 6, 2013 1:26 PM   in reply to Mioux61
    Start by trashing the prefs. See Replace Your Preferences
    Have you removed any fonts from the system?
    Apr 6, 2013 2:35 PM   in reply to Mioux61
    Please create a new user account on your computer and log in with that account and try ID. Do the dialogs work?
    Apr 6, 2013 3:02 PM   in reply to Mioux61
    OK, that does, indeed mean the problem is in the old account, not in ID.
    Log in with the old account again, and use the manual method to remove the prefs from the link I posted earlier, then remove any of the files you find that are on the list at Adobe Forums: InDesign crashes at startup. These are ALL files in the User library, and are hidden files in your version of OS X. If you don't already know how to access hidden files, see Access hidden user library files | Mac OS 10.7 Lion
    When you've done that, restart ID.
    Apr 6, 2013 3:27 PM   in reply to Mioux61
    It's in post # 7.....
    Apr 6, 2013 3:39 PM   in reply to Mioux61
    Try replacing the prefs one more time holding down the Cmd, Control, Opt & Shift keys when you start ID.
    Apr 6, 2013 3:51 PM   in reply to Mioux61
    That should do the trick, so make sure you really got them all. Won't hurt to restart the computer, too.
    Apr 29, 2013 3:14 AM   in reply to Peter Spier
    I'm having the same problem with my CS5 Indesign. The only difference is that I created a new user to check if the problem with the greyed input fields exist in that account and it does. Can anyone advise how I should proceed?
    Apr 29, 2013 4:13 AM   in reply to kreuz287
    If it's not working correctly in a new user I think it means you're missing the system font that is used in the dialogs.
